06 GTO wiring diagram
macdammitman1
Posted: November 27, 2006 at 4:14 PM / IP Logged
Im looking for a wiring diagram for a 2006 Pontiac GTO.
Q Tha Kid
KarTuneMan
Platinum - Posts: 7,056
Posted: November 27, 2006 at 5:14 PM / IP Logged
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Go to battery
 IGNITION Orange Ignition switch harness   +
 These wires are small gauge but can be connected normally.
 ACCESSORY BROWN / white Ignition switch harness   +
 STARTER Violet Ignition switch harness   +
 TACH SIGNAL Use an injector
 LOCK BROWN / white At BCM behind glovebox   -
 UNLOCK Lt.GREEN/ YELLOW At BCM behind glovebox   -
 DOORPIN SEE NOTES
 Drver's door (Gray/white) and Passenger door (White). Both wires are located at the BCM behind the Glovebox.
 TRUNK PIN YELLOW /GREEN At BCM behind glovebox   -
 TRUNK RELEASE BLACK/ red At switch in dash   -
 FACTORY ARM Through OEM remote only
 FACTORY DISARM Through OEM remote only
 System will disarm automatically during remote start when the ignition comes on and the transponder key is installed.
 BRAKESWITCH Blue/red At switch above brake pedal   +
 PARKLIGHTS Brown On fuse box under driver's dash   +
 HORN BLACK / YELLOW At steering column   -
 VSS WIRE Violet/white driver kick panel (at power interface module)   AC
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This will need to be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
macdammitman1
Posted: November 28, 2006 at 2:25 PM / IP Logged
Thanks alot........ Why is it so hard 2 find these digrams??? Is there a site that has all the cars??
Q Tha Kid
Twelvoltz
Platinum - Posts: 2,384
Posted: November 28, 2006 at 5:49 PM / IP Logged
There are a few options that are free without requiring being a dealer to get access. The best I have found is techservices.audiovox.com, completely free and pretty accurate.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
