I found a box, Need advice for subs
rehoredneck11
Member - Posts: 9
Posted: November 29, 2006 at 12:37 AM / IP Logged
I just got my box in and it is 5.5 inches at the top of the box and 8 inches bottom depth for my single cab truck... i have a 1000 watt class d amp...do you think i could fit type r's .... or should i go with something a little shallower??? my box
Here are the specs if it helps you out a little:
Width: 57"
Height: 15"
Top Depth: 5 1/2"
Box Depth: 8"
aznboi3644
Gold - Posts: 2,600
Posted: November 29, 2006 at 12:41 AM / IP Logged
I doubt type r's could fit
djscustomz1
Member - Posts: 44
Posted: November 29, 2006 at 12:56 AM / IP Logged
Type r's will not fit.. guaranteed.. I ran a pair of MTX thunder 6000's in my  truck box they hammered... If you could find a set of those you would be amazed at the notes they produced....  is your box single or double chambered?
I dont care about who has the bigger name in the business... The Bigger the name the Bigger the price. NO BETTER QUALITY!!!
rehoredneck11
Member - Posts: 9
Posted: November 29, 2006 at 1:01 AM / IP Logged
single i think....haven't really looked at it ...so the 6000's bumped?????will take a look
djscustomz1
Member - Posts: 44
Posted: November 29, 2006 at 2:20 AM / IP Logged
If it is a single chambered box it will definatly sound great in the cab of a truck.... I had a dual chamber and a single chamber. the dual chamber design made he subs more punchy and had no real low responce but the single holy doodie for a single cab truck it sounded great.. and hit incredibly hard...
zhalverson
Copper - Posts: 180
Posted: November 29, 2006 at 11:32 AM / IP Logged
I think you went about that backwards.  You should find a sub you like then find a proper box to match it.
You need to figure out the internal volume of the box then find subs that will work with that size enclosure since you already have it.  Or you could sell that box find the subs you like and then get the right enclosure for the subs.  Just make sure whatever way you do it that the subs will perform properly in the enclosure you have.
rehoredneck11
Member - Posts: 9
Posted: November 29, 2006 at 10:02 PM / IP Logged
Anyone have any suggestions on any subwoofer that maybe could fit ..... Has anyone installed a good system in a single cab truck before ..
rehoredneck11
Member - Posts: 9
Posted: November 29, 2006 at 11:07 PM / IP Logged
how are yalls opinions on perfect 12's from infinity.....they dont seem all that bad
aznboi3644
Gold - Posts: 2,600
Posted: November 29, 2006 at 11:37 PM / IP Logged
ED SQ10 has like 3 inches of mounting depth and 300 rms power handling...a couple of these would be good
jonathancullen
Silver - Posts: 282
Posted: November 30, 2006 at 9:55 PM / IP Logged
the perfects are nice subwoofers, but i think they are a little big for your application.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
