07 dodge caliber lower dash
xtremej
Gold - Posts: 1,440
Posted: November 29, 2006 at 8:30 AM / IP Logged
OK first one I have installed a remote start on. Any tips on removing the lower dash with airbag??
xtremej
Gold - Posts: 1,440
Posted: November 29, 2006 at 9:18 AM / IP Logged
WOW, that is a good time. My tip, lots of patience..........
extreme1
Silver - Posts: 1,070
Posted: November 30, 2006 at 11:11 PM / IP Logged
you found the 3 10mm nuts ok then??
Shaughn Murley
Visions Electronics
Red Deer, Alberta
xtremej
Gold - Posts: 1,440
Posted: December 01, 2006 at 7:49 AM / IP Logged
Not sure if he did he was borrowing my log in.  I haven't done one of these yet but I am assuming that you mean the 3 from the back side that hold the bottom of the dash on? I know he spent a lot of time on it.07 dodge caliber lower dash - Last Post -- posted image..
extreme1
Posted: December 02, 2006 at 11:07 PM / IP Logged
that would be them.
I did my first one 2 weekends ago. didn't like running my hood/tach wire over to the passenger side either to go through the only grommet I could find.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
jacqueslacombe
Copper - Posts: 124
Posted: December 03, 2006 at 2:49 AM / IP Logged
Yep  You need to remouved the bold behind ,but not the middle one it's (2) 10mm ,after that pry the plastic cover , the braket +the air bag +the plastic cover will come off as 1 units   you don't need to disconnect the air bag  just pass it throught  the hole off the complette under steering panel  and put it back to it's place temporarely     you should buy the astroshart they will show you how to removed this panel
cocolaboy
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
