bass amp shutting off
DjRDifacs
Copper - Posts: 64
Posted: December 08, 2006 at 10:02 PM / IP Logged
I've been trying to help my nephew with his stereo, and his bass amp keeps shutting off. He's running 2 amps, the other for his high's. The subs are the fosgates, 400 rms 2ohm dvc. the amp is the Alpine MRP-M650. I series wired each sub, the paralleled 'em both. so the amp should be running at 600 rms @ 2ohms, but keeps shutting off. i'm thinking it could be power, he he's running a 4guage setup, 80amps at the battery, and 60 each at the distro. i thinking about getting a bigger fuse and fuse holder for the battery..anyone agree?
Russ
coppellstereo
Silver - Posts: 785
Posted: December 08, 2006 at 10:38 PM / IP Logged
Nope, that shouldnt fix it.
I would check the ground. If it is loose or not making good contact the amp could overheat and cause it to shut down into protect mode.
Are there any lights on the amp when it shuts off?
mauri197
Copper - Posts: 80
Posted: December 08, 2006 at 10:39 PM / IP Logged
is he runnin 3 amps all together or one for bass and one for highs and how many subs
DjRDifacs
Copper - Posts: 64
Posted: December 08, 2006 at 10:40 PM / IP Logged
No lights at all when it shuts off. I also forgot to mention that when 1 sub is hooked it, its fine.. When he wires the second sub, it plays for a bit, then shuts off. The amp will not turn back on until the second sub is unhooked.
Just two amps. one for bass, the other (4 channel infinity amp) for his high's.
mauri197
Copper - Posts: 80
Posted: December 08, 2006 at 10:42 PM / IP Logged
sound to me like you have the wrong load
DjRDifacs
Copper - Posts: 64
Posted: December 08, 2006 at 10:45 PM / IP Logged
Well it's a mono amp, but it seems like it's not stable when it receives a 2 ohm load. But at the same time I don't wanna tell him it's a bunk amp, and have him go replace it, and it does the same thing all over again.
jeffchilcott
Platinum - Posts: 2,483
Posted: December 09, 2006 at 12:25 AM / IP Logged
measure all the coils on the subs and make sure they all measure the same.
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
DYohn
Moderator - Posts: 10,741
Posted: December 09, 2006 at 9:21 AM / IP Logged
Yes, sounds like either the load is too low and/or the gain is too high.  Also possible is the second sub (or the wiring to it) is shorting out.
specialaudio
Copper - Posts: 58
Posted: December 11, 2006 at 7:40 PM / IP Logged
im thinking its the setting on the amp, does it have bass boost?
93' Cutlass
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
