Panasonic Stereo Hookup
r0yal
Copper - Posts: 72
Posted: December 11, 2006 at 10:32 PM / IP Logged
I recieved an old deck for free, but I'm having trouble figuring out what wire goes to what.
This is a picture of the plug.
-The 2 yellows were banded, and said "15a Batt"
- The red wire is banded, with "ACC"
I'm going to assume, the blue is for the antenna.
the purple and green are for the rear speakers. *I know this*
the grey's and whites are for the front speakers. *I know this*
there is 2 blacks, are they both grounds?
and also for the 2 yellows, do they both just hook up to the power, or is one power, and the other is something else?
Thank you
Panasonic Stereo Hookup -- posted image.
r0yal
Copper - Posts: 72
Posted: December 11, 2006 at 11:27 PM / IP Logged
..the deck is a panasonic, if that makes a difference.
geepherder
Platinum - Posts: 3,668
Posted: December 12, 2006 at 7:12 PM / IP Logged
Connect both yellows together. Does one of the blacks have a stripe or are they both solid? You can plug the harness into the deck, and meter both wires to the chassis to see if they're both grounds. It could be that one of them was used in place of another missing wire- perhaps the amp turn on wire.
