Autopage RS-860 LCD
dago52
Member - Posts: 10
Posted: December 21, 2006 at 11:47 PM / IP Logged
I finally received my autopage remote start alarm. I will be attempting to install this alarm in my 2006 4Door  Toyota Tundra. I have a few quick questions before trying to tackle this project.
Do I have to remove the factory keyless entry first?
Should I mount the brain on the driver or passenger side?
Sould I skin and solder the wires to the main harness?
Will I need any relays or diodes for the door locks/lights/remote start?
Thanks for all of the help
mlaurenza
Member - Posts: 33
Posted: December 22, 2006 at 7:04 AM / IP Logged
Do I have to remove the factory keyless entry first?   Nope
Should I mount the brain on the driver or passenger side?   Drivers side. Most all the wires are on the drivers side.
Sould I skin and solder the wires to the main harness? Absolutely
Will I need any relays or diodes for the door locks/lights/remote start? If it is a double cab you will need relays and diodes for door locks. The factory remote will not unlock the doors when remote started so you have to hook up keyless or you will have to use the key to get in when remote started. Get the wires in the door.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 22, 2006 at 8:49 AM / IP Logged
PASSIVE ANTI-THEFTYESTRANSPONDER SEE NOTES
12 VOLTSWHITE/ blue & WHITE/ redIgnition switch harness +
Wires may change color through a connector on the steering column. Please verify both sides of the connector for these colors.
IGNITIONBLACK/ redIgnition switch harness +
IGNITION 2BLACK / YELLOWIgnition switch harness +
ACCESSORYPinkIgnition switch harness +
STARTERBLACK/ whiteIgnition switch harness +
KEY SENSEYELLOW /GREENAt steering column -
TACH SIGNALYELLOW /GREENPin-4 on 28-pin plug at ECM behind glovebox AC
CRANKSHAFT POSITION SENSORGreenPin-23 on 31-pin plug at ECM behind glovebox
FUEL INJECTOROpposite from BLACK/ redAt any injector on engine AC
LOCKLt.GREEN/ blackInside driver's door at switch -
This vehicle requires a special configuration for the doorlocks, please see the doorlock diagram.
UNLOCKLt.GREEN/ red & RED / yellowInside driver's door at switch -
DOORPINSEE NOTES
All the following wires are found at the BODY ECU under the driver's side dash to the far left. WHITE (pin-8 on 18-pin plug) catches all doors. For separate door triggers, use GRAY/RED (pin-15) Driver's door, RED / WHITE (pin-16) Rear left door, both found on 18-pin plug. LT.GREEN/ BLACK (pin-8) Passenger door, RED / WHITE (pin-4) Rear right door, both found on 25-pin plug.
KarTuneMan
Posted: December 22, 2006 at 8:50 AM / IP Logged
 HOODPIN Blue/white In large white connector in DKP   -
 TRUNK PIN Red In back door at ECU module   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH GREEN / WHITE On Gray plug in driver's kickpanel   +
 PARKLIGHTS Green On Black plug in driver's kickpanel   +
 HAND BRAKE Lt.GREEN/ red At switch on handbrake lever   -
 HORN BLACK / YELLOW At steering column   -
 DRIVER WINDOW UP Red At switch in driver's door   REV POL
 DRIVER WINDOW DOWN Green At switch in driver's door   REV POL
 PASSENGER WINDOW UP Red At switch in passenger door   REV POL
 PASSENGER WINDOW DOWN Green At switch in passenger door   REV POL
 LEFT REAR WINDOW UP Red At switch in left rear door   REV POL
 LEFT REAR WINDOW DOWN Green At switch in left rear door   REV POL
 RIGHT REAR WINDOW UP Red At switch in right rear door   REV POL
 RIGHT REAR WINDOW DOWN Green At switch in right rear door   REV POL
 HEADLIGHTS GREEN/ YELLOW Pin-15 on 20-pin plug at ECM behind glovebox   -
 REVERSE LIGHTS RED / black In driver's kickpanel   +
 VSS WIRE GREEN/ orange Pin-5 on 28-pin plug at ECM behind glovebox
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available, contact your supplier to find out. If one is not available to you, please refer to the appropriate security diagram for bypass information.
Additional Notes
WHEN PROGRAMMING THE PATS TOYOTA THE BLACK WIRE FROM PATS TOYOTA MODULE TO GROUND FIRST. AFTER THE BLACK WIRE IS GROUNDED GROUND THE BLUE KEY SENSE WIRE ON THE IGNITION BARREL. DO NOT GROUND AT THE SAME TIME.
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
