03 Denali Windows
justodd
Member - Posts: 26
Posted: December 23, 2006 at 11:48 PM / IP Logged
Is there any way to make the windows roll up/down faster?
thanks
todd
KarTuneMan
Platinum - Posts: 7,056
Posted: December 24, 2006 at 10:25 AM / IP Logged
Why?
justodd
Member - Posts: 26
Posted: December 24, 2006 at 11:11 AM / IP Logged
Because they are really slow.
KarTuneMan
Posted: December 24, 2006 at 11:47 AM / IP Logged
Have you gotten into the doors and cleaned and lubed all the "stuff" that makes then go up and down. You can't make the motor go any faster....
justodd
Member - Posts: 26
Posted: December 24, 2006 at 12:27 PM / IP Logged
I will give that a try.
thanks,
todd
01rado
Member - Posts: 7
Posted: January 07, 2007 at 4:21 PM / IP Logged
There IS a way to make the windows move faster, it's a bit complicate.  If you are still looking hit me up with a PM and I will put it on here for all to see.
Evan
Evan Zerby
Living to do the impossible.
KarTuneMan
Posted: January 08, 2007 at 8:34 AM / IP Logged
01rado...could you breifly explain to all of us how you are safely going to make the power window motors turn faster? I'm VERY interested.
01rado
Member - Posts: 7
Posted: January 10, 2007 at 6:23 AM / IP Logged
Breifly...No, but I will work on a diagram here in a few hours and try to get it up for you.  First things first, he needs get it all cleaned and lubbed up well.  I use a good spray on white lithium grease.
Evan Zerby
jayno20
Copper - Posts: 76
Posted: January 10, 2007 at 7:24 AM / IP Logged
mine have just recently started going pretty slow... i figured it was the cold weather because they seemed fine before...
KarTuneMan
Posted: January 10, 2007 at 8:05 AM / IP Logged
hello......anything on the speeding up of the motors (safely) ?
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
