alpine swr1242d
raven2122
Posted: January 01, 2007 at 5:09 PM / IP Logged
I was reading in the info that came with my sub that the recommended enclosers are sealed, ported and bandpass.  It gives the ideal volum for the sealed and ported box's but not bandpass.
How much room do I need?
nmd
actypes
Member - Posts: 17
Posted: January 01, 2007 at 6:40 PM / IP Logged
i wouldnt recommend using a bandpass enclosure.  The SQ from it is going to be very poor.  Ideally an alpine type r will sound its best in a sealed or ported enclosure..  It all depends on whether or not you want loud boomy bass, or nice tight bass
stevdart
Platinum - Posts: 5,816
Posted: January 01, 2007 at 8:15 PM / IP Logged
I recommend a vented box for that sub, built a bit larger than the manual indicates.  Instead of net internal volume at 1.3, make it 1.8 cu ft.  Port, slotted, with 14 sq in of opening area and no less than 1.5" wide (2 X 7 is good).  Usually these slot ports are built the length of the internal box height, but the 1.25" the manual indicates is too narrow, IMO.  (I also dropped the port sq in opening down from the indicated 15" to 14 sq in.)  Port length 21 3/4".  Of course, the port structure takes up airspace so you have to calculate how much it is going to displace.  Tuning freq and F3 is at 29 Hz.
aznboi3644
Gold - Posts: 2,600
Posted: January 02, 2007 at 7:59 PM / IP Logged
You are probably thinking prefab bandpass boxes...if that is the case than yes sound quality will be crap and the bass will be boomy and sound like crap.
But a properly designed and built bandpass enclosure can have excellent sound quality and a flat response...I think you are misunderstanding the bandpass box.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
