no output from amp
smitty93
Posted: January 02, 2007 at 8:41 PM / IP Logged
i bought new speakers for my truck and i have them running directly to my amp but no sound comes out of it, anybody know what could be wrong
Smitty
haemphyst
Platinum - Posts: 5,054
Posted: January 02, 2007 at 9:18 PM / IP Logged
Is the deck working? How do you know it is or is not? Is the amp working? How do you know it is or is not? Is the wiring to the speakers good? Did you replace the stock wiring, or did you tap into the harness?
Tell us what you have done to troubleshoot, so we can help you. We could suggest things to check all day long, and still never trip across the solution.
smitty93
Posted: January 03, 2007 at 5:12 PM / IP Logged
yes the deck and amp are working  i bought brand new wire for my speaker, the speaker wire runs right out of my amp to my speakers that I bought, I was planing to just have the speakers in the back seat or underneith because there is lots of room back there
Smitty
haemphyst
Posted: January 03, 2007 at 6:20 PM / IP Logged
OK, that's fine, but again, what have you done to troubleshoot?
How do you KNOW all the components are functioning correctly? Is the amp powering up? Are there any fuses blowing? What deck, amp, and speakers are you trying to install? I can't read your mind, you have to help us out a bit, or we can't help you...
specialaudio
Copper - Posts: 58
Posted: January 03, 2007 at 6:40 PM / IP Logged
Check the RCAS, do you have Rcas? is there any input into the amp?
is the amp in troble mode? is it on? do you have a good ground?  what kind of amp?
do you have a tigger or REM into the amp?
need more info....
93' Cutlass
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
