Remote Starter, 2002 Chevy Tracker
zombie69
Member - Posts: 6
Posted: January 10, 2007 at 6:18 AM / IP Logged
I just Installed a Prestige APS-686T remote starter in a 2002 Chevy Tracker. The problem I am haveing is the Tach signal, The Tracker has 4 individual coils 1 for each cyclinder. The Instalation manual says I might havre to hook the tach wire to multiable coils see mutiple coil wiring. And says I need (P/n 136b1400) to hook all the coils together. But were do I get this adapter? And do I need it?
brhaugen
Copper - Posts: 275
Posted: January 10, 2007 at 6:41 AM / IP Logged
You should not need any adapters. Tach is the brown wire Pin4 of the C1 Connecter at the PCM - PCM is behind the gove box
TACH =
zombie69
Member - Posts: 6
Posted: January 10, 2007 at 4:14 PM / IP Logged
I will try and let you know what happens thanks.
zombie69
Member - Posts: 6
Posted: January 15, 2007 at 7:11 AM / IP Logged
I tried hooking into the brown wire pin 4 of the PCM but still have the same problem? Car will start but will not stay running? Any help would help thanks.
xtremej
Gold - Posts: 1,440
Posted: January 15, 2007 at 8:19 AM / IP Logged
Are there multiple brown wires at the ECM thats behind the glove box? Did you verify with a multimeter that you in fact are on the right one. Is you remote start set to sense tach? I checked all of my diagrams and they all call for the brown at the ECM behind the glove box..
Hymer
Silver - Posts: 695
Posted: January 15, 2007 at 8:51 AM / IP Logged
Looks like the 3rd wire top row of the 1st plug [left to right] under the glove box
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
zombie69
Member - Posts: 6
Posted: January 15, 2007 at 12:26 PM / IP Logged
What should be my reading on the meter? And what do i set the meter for? Thanks
xtremej
Gold - Posts: 1,440
Posted: January 15, 2007 at 3:00 PM / IP Logged
well i set my meter to voltage and usualy it will read between 1.6 volts or so and then rev it up a little and the voltage should raise.
zombie69
Member - Posts: 6
Posted: January 15, 2007 at 3:31 PM / IP Logged
Thanks for the help will try and post what happens. Thanks Again
mbaudio06
Copper - Posts: 60
Posted: January 15, 2007 at 3:40 PM / IP Logged
I would try the cluster..
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
