subwoofer vocals
lamigra05
Member - Posts: 39
Posted: January 29, 2007 at 11:15 PM / IP Logged
hello, i bought the mtx 9500 DVC sub with the mtx 7801 amplifier and i started noticing that the sub was actually playin music. it kind of distorted the sound also. and i didnt remember music comin out of my old subs, i was just wondering if that was a problem. maybe i wired sumthin wrong. but i would apreciate it if sumone just told me if anything was wrong at all. if not then thanks..
wat it do?
Ravendarat
Platinum - Posts: 2,806
Posted: January 30, 2007 at 12:26 AM / IP Logged
Your crossover is set improperly. Make sure its set to low pass and set to the correct level, generally under 100hz
jettagli03
Copper - Posts: 311
Posted: January 30, 2007 at 1:17 PM / IP Logged
Yeah, if you're a DIY then you should probably read the sticky about setting gains.. and then also read up on frequencies it sounds like.
Tuesday, June 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
