DEI Lists:
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / ELANTRA / 2007 / Remote Start
[PRINT THIS PAGE]
12volts black (40A), red (30A) + ignition harness
Starter white + ignition harness
Second Starter N/A
Ignition blue + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory pink + ignition harness
Second Accessory yellow + ignition harness
Keysense green + ign harn or BCM, wht 24P plug, pin 4
Notes: The BCM (Body Control Module) is in the center dash, behind the A/C controls.
Power Lock green - dr kick or BCM, wht 20P plug, pin 3
Power Unlock yellow - dr kick or BCM, wht 20P plug, pin 11
Lock Motor gray 5wi driver kick, gry 39 pin plug, pin 38
Unlock Motor yellow 5wi driver kick, gry 39 pin plug, pin 30
Parking Lights+ yellow (L), BROWN / orange (R) + fuse box, 30 pin plug, pins 22 and 6
Parking Lights- blue - switch or BCM, wht 20P plug, pin 4
Hazards green - BCM, gray 24 pin plug, pin 9
Turn Signal(L) yellow/orange + switch or fuse box, 30P plug, pin 26
Turn Signal(R) blue + switch or fuse box, 30P plug, pin 11
Reverse Light gray or brown + fuse box, 30 pin plug, pin 13 or 14
Door Trigger yellow - dr kick or BCM, wht 24P plug, pin 22
Dome Supervision yellow - dr kick or BCM, gry 24P plug, pin 1
Trunk/Hatch Pin green to GREEN/ black - dr kick or BCM, wht 24P plug, pin 23
Hood Pin green - pin sw or BCM, wht 24P plug, pin 24
Trunk/Hatch Release white - dr kick or BCM, wht 20P plug, pin 13
The trunk release motor wire is orange (+) in the fuse box, 30 pin plug, pin 28.
Power Sliding Door N/A
Factory Alarm Arm green - dr kick or BCM, wht 20P plug, pin 1
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm blue to yellow - dr kick or BCM, wht 20P plug, pin 2
Disarm No Unlock with ign, acc, and key sense
Tachometer blue or red ac pass kick, gray 39 pin plug, pin 5
Notes: Also found at the instrument cluster, white plug, pin 20.
Can also go to any fuel injector and use the wire that is NOT white.
Wait to start N/A
Brake Wire white to black + sw or dr kick, gray 39P plug, pin 34
Parking Brake blue - sw or fuse box, 20 pin plug, pin 8
Horn Trigger red or GREEN/ orange - switch or BCM, gry 24P plug, pin 8
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Only Canadian models have the immobilizer system.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
You would need to energize keysense, yes. If you look at the notes for disarm/no unlock it specifies that the factory alarm will disarm with keysense, ignition and accessory. You do not mention which system you are installing, but with the DEI systems I use there is a status output wire that you would use to power a relay to provide +12V to the vehicle's keysense wire during remote start. You may also be able to just use the second ignition output to power it if your vehicle does not require both accessories for remote start.
