2007 ford f350 diesel remote start
dereck
Member - Posts: 28
Posted: February 01, 2007 at 7:51 PM / IP Logged
Hi I am looking for the wiring info for a 2007 Ford F350 Diesel for a remote start.
Hymer
Silver - Posts: 695
Posted: February 01, 2007 at 8:22 PM / IP Logged
same as the 04-05-06... nothing different...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
throwback2332
Member - Posts: 41
Posted: February 01, 2007 at 8:58 PM / IP Logged
MODEL YEAR(S)
F SERIES SUPER DUTY   2006 -
KEY T-HARNESS IMMOBILIZER
N/A    N/A    N/A
PART   COLOR LOCATION
12 VOLT CONSTANT   YELLOW (+) and LIGHT GREEN/ PURPLE (+)    @ IGNITION SWITCH HARNESS
STARTER DARK GREEN (+)   @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 RED / LIGHT GREEN (+)   @ IGNITION SWITCH HARNESS
IGNITION 2 RED / BLACK (+)   @ IGNITION SWITCH HARNESS
IGNITION 3 N/A
ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+)   @ IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2 DARK/BLUE/LIGHT GREEN (+)   @ IGNITION SWITCH HARNESS
KEYSENSE N/A
PARKING LIGHTS ( - ) N/A
PARKING LIGHTS ( + ) BROWN (+)   @ HEADLIGHT Switch or VSM, GREEN Plug, Pin 2, See NOTE *1
POWER LOCK PINK / YELLOW (TYPE C) See NOTE *2   in DRIVERS KICK PANEL, @ DOOR HARNESS
POWER UNLOCK PINK/LIGHT GREEN (TYPE C) See NOTE *2   in DRIVERS KICK PANEL, @ DOOR HARNESS
DOOR TRIGGER Use DOMELIGHT Supervison wire
DOMELIGHT SUPERVISION BLACK/ LIGHT BLUE (+)   @ PASSENGER KICK PANEL or Cluster Blue Plug, Pin 26
TRUNK RELEASE N/A
SLIDING POWER DOOR N/A
HORN DARK BLUE (-)   @ HORN SWITCH or VSM, GREEN Plug, Pin 6, See NOTE *1
TACH See NOTE *3
WAIT TO START LIGHT See NOTE *4
BRAKE LIGHT GREEN (+)   @ SWITCH above BRAKE PEDAL
FACTORY ALARM DISARM   N/A
ANTI-THEFT N/A
EXTRA INFORMATION
NOTE *1 The VSM (Vehicle Security Module) is located to the RIGHT of the GAS Pedal, just above the Transmission hump and below the Radio. the VSM is NOT Accessible from the Radio opening. NOTE *2 Vehicles WITHOUT a FACTORY KEYLESS Entry Remote Control are a TYPE "C" Door Locking System. Vehicles WITH a FACTORY KEYLESS Entry Remote Control are a TYPE "B" Door Locking System and the LOCK wire is a WHITE/ RED (TYPE B) and the UNLOCK is a BLACK/ WHITE TYPE B), BOTH are located in the Drivers Kick Panel, at the Door Harness. NOTE *3 On GAS Engines the TACH wire is any wire that is NOT: RED / LIGHT GREEN or RED / YELLOW at any IGNITION COIL or FUEL-INJECTOR. On DIESEL Engines the TACH wire is a LIGHT GREEN / WHITE wire in a 5-Pin Harness held up with WHITE tape located behind the Parking Brake Release. NOTE *4 On this vehicle you can not use the WAIT TO START wire, you must use the WAIT TO START TIMER Programming in your Installation manual.
If it's not custom, then it's not you.
dereck
Member - Posts: 28
Posted: February 02, 2007 at 9:30 PM / IP Logged
What is the Type B lock and unlock, is this a positive or negative, 3 wire or 4 wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: February 02, 2007 at 9:38 PM / IP Logged
Door locks are negative.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
