problems with omega db dlm modules
NismaX
Copper - Posts: 104
Posted: February 02, 2007 at 7:45 AM / IP Logged
Hi
I have been installing automotive products for years now and have never had as many issues as with these omega db-dlm modules. They have been particually troublesome in '03 and up Chevy trucks, Tahoes and Suburbans with the databus locks. The problem is that they just quit working after a year or so. Omega is great about exhanges but this is really getting tiresome. Talking to tech support isn't getting any place. These are simple enough to hook up with power ground data lead and door lock wires. I have been using AST's remote starters for the past few years and they have been working very well with few issues. Does anybody have any input for what might be happening. The only thing I can figure out is maybe the output of the AST R/S is somehow dirty. I know they aren't dual polarity which I could see as a problem. Any input would be helpful at this point.
Thanks in advance
Jon
Traveling Electronics
Chris Luongo
Platinum - Posts: 3,746
Posted: February 02, 2007 at 8:17 AM / IP Logged
Are those rebadged pieces from Trilogix, or something different?
Where are you getting your constant power source?
I've noticed that some installers like to get constant and ground at the car's OBDII plug. That constant wire also share's the car's cigarette lighter fuse. And Trilogix modules don't have a memory, and often have to be reset if they lose power.
If the unit is wired for constant at the OBDII plug, and the customer blows and then replaces the lighter fuse, the Trilogix unit sometimes has to be reprogrammed.
Not sure if the Omega stuff is the same. Next install you do, after you're finished, unplug it for a few minutes, plug it back in, and see if it still works.
xtremej
Gold - Posts: 1,440
Posted: February 02, 2007 at 10:48 AM / IP Logged
Yes, omega bypasses are rebadged trilogix pieces.
NismaX
Copper - Posts: 104
Posted: February 03, 2007 at 7:37 AM / IP Logged
Hi and thanks for the replys
I'm using the chassis ground in the kick pannel and the positive right from the ign harness. These have got to be the best sources for this that I'm aware of. The remote starts themselves have few issues with these sources of power. I don't use any of the ground or power from the Passlock wiring. Although I did notice that Omega changed where they get power and ground from in one of the newest bypass kits. It's from of all places the Passlock wiring.
Jon
NowYaKnow
Gold - Posts: 1,217
Posted: February 03, 2007 at 1:37 PM / IP Logged
As mentioned most likely losing power. Pop the hood and/or ask if they recently got a new battery or had any service done on the vehicle. Just reprogram the bypass and send the customer on their way.. It's still much less of a hassle then putting relays in the doors.
Mike
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
