horn honk on r/s shutsown 04 trailblazer
xtremej
Gold - Posts: 1,440
Posted: February 26, 2007 at 5:03 PM / IP Logged
Does it say on the remote which trigger is open ie setting it off. Maybe its possible that the domelight is triggering it?. If you have the door trigger hooked to the gmdl-bp try just hooking it into the alarm brain (only) input and see if that works. Just an idea I haven't really expereinced this trouble on trailblazer.
Hymer
Silver - Posts: 695
Posted: February 26, 2007 at 5:04 PM / IP Logged
Did ya use the door pin output on the bypass or the ones on the vehicle?    Iv'e heard of chevs doing this when you use the door trigger off he gmdlbp bypass.. [don't know if the Omega version has this feature but???]
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
jmacf14
Copper - Posts: 160
Posted: February 26, 2007 at 8:28 PM / IP Logged
I used the input from the module. Should I try to take the input directly to the r/s unit from the rig, instead of from the bypass module? (I'll also verify from the remote what is triggering, thanks for the idea xtremej)
jmacf14
xtremej
Gold - Posts: 1,440
Posted: February 27, 2007 at 7:39 AM / IP Logged
Hymer fyi the omega db-gmdl-bp is made by trilogix aka bypasskit.com. jmac let me know how it turns out I have a customer that wants an alarm start put in there trailblazer.
jmacf14
Copper - Posts: 160
Posted: February 27, 2007 at 8:20 AM / IP Logged
I am going to look at it again this afternoon. I'll keep it for a couple of hours, monitor the remote, and trydisconnecting the dome input to the module. we will see. I'll keep you posted.
jmacf14
Hymer
Silver - Posts: 695
Posted: February 27, 2007 at 10:05 AM / IP Logged
I kinda figured it was made by trilogix, but yes, I would use the actual door pins on the truck itself. Its a pain because of having to get them in the driver and pass door, and the rears are in the door boots, but at least your not fighting with the bypass [something you can't neccisarrally verify is working.] I have had issues with crew cab chevs where the rear doors can be opened and the alarm wont trigger, or it will trigger a few minuts later. Doing it the real way, will ensure a (-) is sent as soon as that door is opened and the alarm sounds...
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
