infiniti qx56 remote start wiring diagram
electriqtion
Member - Posts: 20
Posted: February 26, 2007 at 12:34 AM / IP Logged
Do anyone have the wiring diagram for the 2005 Infiniti QX56?
Electriqtion
Twelvoltz
Platinum - Posts: 2,384
Posted: March 01, 2007 at 8:22 AM / IP Logged
DEI lists:
DIRECTWIRE™ WIRING INFORMATION - INFINITI / QX56 / 2005 / Remote Start
[PRINT THIS PAGE]
12volts      green (40A)       +       ignition harness
Starter      brown       +       ignition harness
Second Starter      lt. green or blue/green       +       ignition harness
Ignition      BLACK/ red       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      red       +       ignition harness
Second Accessory      purple       +       ignition harness
Keysense      RED / blue to BLACK/ red       +       ign harn or BCM R of column, pin 37
Power Lock      blue       -       driver door module in door, pin 4
Power Unlock      red (double pulse)       -       driver door module in door, pin 6
Lock Motor      purple       5wi      BCM to right of column, pin 65
Unlock Motor      green       5wi      BCM to right of column, pin 59
Parking Lights+      RED / blue       +       either kick, harness to rear
Parking Lights-      N/A
Hazards      WHITE/ black       -       BCM to right of column, pin 29
Turn Signal(L)      GREEN/ black       +       BCM to right of column, pin 60
Turn Signal(R)      GREEN/ YELLOW       +       BCM to right of column, pin 61
Reverse Light      GREEN / WHITE       +       passenger kick, harness to rear
Door Trigger      see notes       -       BCM to right of column
Notes: The LF door trigger is lt. blue in pin 47. The RF door trigger is RED / blue in pin 12. The LR door trigger is RED / yellow in pin 48. The RR door trigger is RED / white or gray in pin 13. Use all four wires and diode isolate each.
Dome Supervision      blue       -       BCM to right of column, pin 63
Notes: The blue wire is for the dome lights and puddle lights. For the step lights use RED / white in pin 62 at the BCM.
Trunk/Hatch Pin      RED / black       -       BCM to right of column, pin 43
Notes: The RED / black is for the liftgate pin. For the glass hatch pin use gray in pin 42 at the BCM.
Hood Pin      yellow/black       -       hood pin switch under hood
Trunk/Hatch Release      yellow/brown or yellow/red       -       BCM to right of column, pin 30
Notes: For the power liftgate use blue/white (-) at the power liftgate switch on the dash.
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      disarms with unlock
Disarm No Unlock      single pulse power unlock wire
Tachometer      NOT WHITE/ blue or black       ac       any ignition coil
Wait to start      N/A
Brake Wire      RED / green       +       brake pedal switch
Notes: The brake wire is also RED / black in either kick panel, in the harness going to the rear.
Parking Brake      green       -       parking brake switch or cluster
Horn Trigger      RED / white       -       horn switch
Memory Seat 1      lt. GREEN/ black       -       memory mod. left of column, pin 9
Memory Seat 2      pink/blue       -       memory mod. left of column, pin 25
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Door Lock Interface      Required:
No      Type:
Data Bus
Part #: IM-Nissan-1
Notes:
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Engine compartment fusebox, Passenger side
Part #: 6408A
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
electriqtion
Member - Posts: 20
Posted: March 01, 2007 at 3:10 PM / IP Logged
Thanks.
Electriqtion
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
