car alarm
brucey
Posted: February 27, 2007 at 10:57 AM / IP Logged
i odered an asianwolf.com, it is a fm 2009 v2.0 package deal 4, to be installed on a 2005 chevy  impala, need a wiring diagram to ease the install. in the package is a window roll-up module and radar motion sensor. i have installed alarms before but am new to posting, so be kind.
warpedimage3
Copper - Posts: 90
Posted: February 27, 2007 at 12:31 PM / IP Logged
< color=#606420>12volts red (x2)(common 60A)  +  ignition harness
< color=#606420>Starter yellow  +  ignition harness
< color=#606420>Second Starter N/A
< color=#606420>Ignition pink  +  ignition harness
< color=#606420>Second Ignition dk. green  +  ignition harness
< color=#606420>Third Ignition N/A
< color=#606420>Accessory orange  +  ignition harness
< color=#606420>Second Accessory brown  +  ignition harness
Notes: This wire must be powered as an accessory wire. If powered as a second ignition, the car will not crank.
Keysense lt. green  -  ign harn or BCM, gry 16P plg, pin B1
Notes: The BCM is under the driver side dash, above the parking brake lever.
< color=#606420>Power Lock ORANGE / black  -  BCM, gray 24 pin plug, pin B3
Notes: Lock is negative trigger thru a 470 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
< color=#606420>Power Unlock same as power lock wire
< color=#606420>Lock Motor see notes
Notes: Installation of factory keyless upgrade alarm is not recommended on this vehicle because the door lock motor wires rest at approximately 7 volts.
< color=#606420>Unlock Motor see lock motor notes
< color=#606420>Parking Lights+ yellow (F), BROWN / white (R)  +  passenger junction block end of dash
< color=#606420>Parking Lights- white  -  BCM, pink plug, pin A2
Must diode isolate this wire from the BCM to avoid Service Engine Soon light. See DirectFax document 1600 for wiring information.
Hazards same as turn signal wires
Turn Signal(L) lt. blue (F), yellow (R)  +  turn signal switch
Turn Signal(R) dk. blue (F), dk. green (R)  +  turn signal switch
Reverse Light lt. green  +  passenger junction block end of dash
< color=#606420>Door Trigger dk. blue (L), dk. blue/wht (R) -  BCM, gray 16 pin plug, pins A8, A1
Notes: Use both wires and diode isolate each. Have to also diode isolate from the BCM to prevent false alarms. Refer to DirectFax document 1076 for wiring information.
< color=#606420>Dome Supervision gray  -  BCM, gray 24 pin plug, pin A8
< color=#606420>Trunk/Hatch Pin RED / black  -  BCM, gray 24 pin plug, pin A11
< color=#606420>Hood Pin N/A
< color=#606420>Trunk/Hatch Release black  -  BCM, gray 16 pin plug, pin A7
Power Sliding Door N/A
< color=#606420>Factory Alarm Arm arms on lock with door open
< color=#606420>Factory Alarm Disarm lt. green  -  BCM, gray 16 pin plug, pin B3
< color=#606420>Disarm No Unlock see factory alarm disarm
< color=#606420>Tachometer white  ac  Ignition Control Module
Notes: On the 3.4L it is on the top center rear of the engine. On the 3.8L it is on the top right front of the engine.
Wait to start N/A
< color=#606420>Brake Wire white  +  brake pedal switch
Parking Brake lt. green  -  BCM, gray 16 pin plug, pin B6
< color=#606420>Horn Trigger black  -  BCM, pink plug, pin B5
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
car alarm -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 1100F
Alternate Part1 #: 1100X
Alternate Part2 #: 556LW
Alternate Part3 #: 555LW
Alternate Part4 #: DesignTech 20402
Alternate Part5 #: DesignTech 29402
Notes: Standard on all models. The Passlock II wire colors are yellow, black, and white (not used). When using the 1100F or 1100X, a software change to 1100GM is needed.
Door Lock Interface
Required:
No
Type:
Data Bus
Part #: IM-GMSD-1
Alternate Part1 #: 456LW
Notes:
Combo Interface
Required:
No
Type:
Data Bus
Part #: 1700G
Alternate Part1 #: 457GW
Notes: Can use the 1700G or 457GW to bypass the Passlock II, but it will not control the door locks on this model year.
Smart Starter Kill Relays:Relay Type:
Starter Relay
Engine compartment fusebox, Passenger side
Part #: 6402A
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
