2007 lexus gx470
Mr_Fusion
Copper - Posts: 113
Posted: March 04, 2007 at 9:12 PM / IP Logged
Looking for a remote start/security diagram for the above vehicle...thank you!
master5
Silver - Posts: 1,123
Posted: March 04, 2007 at 9:41 PM / IP Logged
This is for an 06 but should be identical. test with a DMM as you are fully responsible if any info is wrong and you mess up.
Knock yourself out....
12volts  wht/blue (50A), wht/red (30A)   +   ignition harness
Starter  GREEN/ black   +   ignition harness
Second Starter  BLACK/ white   +   ignition harness
Ignition  BLACK/ red   +   ignition harness
Second Ignition  blue / YELLOW   +   ignition harness
Third Ignition  N/A
Accessory  WHITE/ green   +   ignition harness
Second Accessory  N/A
Keysense  GREEN/ YELLOW   -   ignition harness
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors.
Power Lock  GREEN/ black to BLACK/ orange   -   passenger kick, gray 18 pin plug
Can also use the driver door key cylinder wires for lock/unlock. The lock wire is blue (-), and the unlock wire is green (-, double pulse). These wires are at the driver door module in the door.
Power Unlock  green   -   passenger kick, gray 18 pin plug
Notes: Meter these wires while turning the key in the passenger door key cylinder.
Lock Motor  blue/red to RED / black   5wi  driver kick, 13 pin plug
Unlock Motor  blue/orange to BLACK/ white   5wi  driver kick, 13 pin plug
Parking Lights+  green   +   left of fuses, 16 pin plug
Parking Lights-  green   -   BECU, top plug, pin 8
 Hazards  white   -   hazard switch
Turn Signal(L)  blue/black   +   left of fuses, 16 pin plug
Turn Signal(R)  blue / YELLOW   +   left of fuses, 16 pin plug
Reverse Light  RED / black   +   passenger kick, harness to rear
Door Trigger  purple / YELLOW (ajar indicator)  -   BECU, top plug, pin 12
Notes: The individual door trigger wires are in the BECU, middle plug. The LF door is RED / yellow in pin 23.
The RF door is RED / yellow in pin 24. The LR door is pink/black in pin 11. The RR door is pink/blue in pin 12.
Use all four wires and diode isolate each.
Dome Supervision  white   -   plug to right of fuses, pin 8
Trunk/Hatch Pin  RED / blue   -   BECU, middle plug, pin 7
Hood Pin  RED / white   -   driver kick, large plug by firewall
Factory Alarm Arm  arms with lock
Factory Alarm Disarm  disarms with unlock
Disarm No Unlock  use key sense wire
Tachometer  BLACK/ white   ac   ECM, second plug from top, pin 1
Notes: The ECM (Engine Control Module) is behind the glove box.
Brake Wire  GREEN/ YELLOW   +   left of fuses, 16 pin plug
Parking Brake  GREEN/ red   -   BECU, middle plug, pin 2
Horn Trigger  GREEN/ red   -   horn switch
Memory Seat 1  blue/orange   -   BECU, bottom plug, pin 20
Memory Seat 2  blue/black    -   BECU, bottom plug, pin 2
The Body ECU is part of the fuse box under the driver side dash.
The three plugs on the right side edge of the fuse box are for the Body ECU.
Immobilizer Bypass  Required
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
