98 expedition remote start
mrcllusb
Copper - Posts: 489
Posted: March 20, 2007 at 5:39 PM / IP Logged
My neighbor has a 98 expedition that had a auto command remote starter in it that died.I told him to buy another DEI remote starter and i would swap it out for him.He bought a Ready Remote model 24926.I just transfered the wiring from the old unit to the new one,and the vehicle will crank but it won't start.Any suggestions
"ole blake"
rudydapimp
Copper - Posts: 390
Posted: March 20, 2007 at 6:16 PM / IP Logged
did you hook up a tach wire?? What bypass did you use??? DEi 556U, DEI 555F, or similar
mrcllusb
Copper - Posts: 489
Posted: March 20, 2007 at 6:33 PM / IP Logged
That's just it,the systems are both made by DEI and the previous model didn't need a bypass,and didn't use a tach signal,it used the voltage sensor.
"ole blake"
rudydapimp
Copper - Posts: 390
Posted: March 20, 2007 at 8:34 PM / IP Logged
did you program the voltge sense and set the correct crank time??Does the security light flash on the dash???
xtremeaudio
Copper - Posts: 174
Posted: March 21, 2007 at 12:00 AM / IP Logged
all you need to do program to voltge or tach it will work
mrcllusb
Copper - Posts: 489
Posted: March 21, 2007 at 5:18 AM / IP Logged
I'm just going to program the tach wire because the voltage sensor is telling me that the voltage drops to low when the vehicle tries to crank.
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: March 24, 2007 at 12:09 PM / IP Logged
Tried both ways,and vehicle will crank,but not start.I tried setting the crank time longer,but that didn't work either.Any suggestions?
"ole blake"
Twelvoltz
Platinum - Posts: 2,384
Posted: March 24, 2007 at 12:36 PM / IP Logged
The most reliable way to install a starter is by using a tachometer monitoring connection. I would recommend hooking it up. With that said, voltage sensing should work fine. DEI systems do not like a battery that is weak, I would suggest having the battery load tested.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
