anti theft lite on, 99 pontiac sunfire
alexlloyd
Member - Posts: 24
Posted: March 30, 2007 at 9:36 PM / IP Logged
99 Pontiac Sunfire 5 speed coupe. No start. Before you blast me for the wrong forum, does the fact that the anti-theft light is on disable the starter crank circuit. There appears to be no power at the clutch switch wires.  Am I on the right track, and what forum do I need for the rest of the story.
mikvot
Gold - Posts: 1,043
Posted: March 30, 2007 at 9:41 PM / IP Logged
Are you adding a remote start, or does the car just not start with the key?.....The car does have passlock which could cause the car not to fire, but it should still crank.
Moderator - Posts: 12,488
Posted: March 30, 2007 at 9:43 PM / IP Logged
You can leave the post here. If the starter cranks and doesn't stay running, it's the Passlock system engaged. The Passlock light will be flashing on the dash. If there's no Passlock light on with the key in the ON position and no cranking of the engine, then there's a different problem. Check to see that the starter fuse isn't blown as well as the starter relay is in fact still good.
410440
Copper - Posts: 82
Posted: April 03, 2007 at 2:40 PM / IP Logged
unhook your battery, touch the positive and negative cables together to discharge system while unhooked, let sit for 5-10 mins, check all fuses rehook up battery and see what happens.
Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
