2007 gmc sierra alarm
walkeraudiosale
Member - Posts: 17
Posted: March 31, 2007 at 10:36 PM / IP Logged
I'm installing a galaxy 5100rs alarm on a 2007 gmc sierra can anyone help me trouble shoot the door locks, dome light and the remote start. I also need help finding what the wiring diagram calls a  "A pilar" that is the location for all door trigger. If anyone can help that would be awesome. Thanks
Dubb
Audio Kings Inc.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 31, 2007 at 11:25 PM / IP Logged
The "A" pillar is where the wimdsheild meets the door. Open the door and grab the front glas AND the car at the same time. THAT'S the A pillar. The B pillar is the next part of the body where the front door meets the back door. C pillar....yup, at the back window.    Trouble shoot, is a vague word without more info? What is the problem with the door locks, dome light, and remote start???
walkeraudiosale
Member - Posts: 17
Posted: April 01, 2007 at 7:24 PM / IP Logged
I thought the door locks were reverse polarity but they are not working. As far as the remote start I am getting a passlock II so that I can by past the factory anti-theft. On the doom light were is located on the A Pilar that why I was needing to know were that was, and thanks for the fast response by the way. Do you think I will need a single wire door lock interface for this car?
Dubb
Audio Kings Inc.
docsautomotive
Copper - Posts: 66
Posted: April 01, 2007 at 10:14 PM / IP Logged
Mike M2
Platinum - Posts: 2,652
Posted: April 02, 2007 at 6:39 AM / IP Logged
Doc's info is for the new bodystyle. Is the truck new style or Classic?
Mike M2
Tech Manager
CS Dealer Services
walkeraudiosale
Member - Posts: 17
Posted: April 02, 2007 at 9:02 AM / IP Logged
The truck is new style.. Thanks 2007 gmc sierra alarm -- posted image. Where do I find the DLS 1 AND 2?
Dubb
Audio Kings Inc.
Moderator - Posts: 12,488
Posted: April 02, 2007 at 9:10 AM / IP Logged
Use a door lock and bypass module combo for this vehicle. It will save you hours of going into each door for door locks as well as running wires. ADS-DL from iDatalink or the XK series from bypasskit will work.
walkeraudiosale
Member - Posts: 17
Posted: May 29, 2007 at 10:28 AM / IP Logged
I'm having the same problem with the door locks on a 2007 GMC Sierra Classic Now.. Any suggestions?
Dubb
Audio Kings Inc.
JWorm
Platinum - Posts: 2,208
Posted: May 29, 2007 at 1:33 PM / IP Logged
You would use a tech sheet for the fullsize GM trucks from 2003-2006. There are many bypasses that would work. Trilogix GMDL-BP, DEI 457G, or the DEI 1700G are 3 modules that would work.
jim hunter
Silver - Posts: 351
Posted: May 29, 2007 at 4:15 PM / IP Logged
the new body style 07 gm trucks have a very wild door lock setup, the doc above will not work, trilogix( which d.e.i. just finalized purchasing)has a interface to do doorlocks thru data, d.e.i. makes 1 the 1701yg but ive heard their having problems with it, too complex&time consuming to wire up with just relays, also truck does not have passlockII, it has pk3+ which will require an extra key and a universal bypass module for key to be installed into, i just sell my dealers a 1 button starter only as door locks are a pain,you casn program the extra key yourself and it wouldnt need to be cut just pick up a spare key from dealership(around 40.00 i believe)and just program it when starter is installed that way you dont need to put a cut key in the bypass
Wednesday, May 1, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
