2008 ford escape wiring and bypass
bbtaco
Copper - Posts: 119
Posted: April 18, 2007 at 2:30 PM / IP Logged
Anyone have the wiring information for a 2008 Ford Escape? My daughter is wanting me to install an RS that can be activated from the factory remote. I told her the range would be very limited but that is what she wants. I plan on installing a DEI 562T. That way she will have the DEI remotes if she wants to use them. Also which is the best bypass to use? Thanks!
mikvot
Gold - Posts: 1,043
Posted: April 20, 2007 at 7:34 PM / IP Logged
I have one to do on monday....i'll get the info for you. For the module i'm gonna use a keyoveride sl2 by Fortin.
bbtaco
Copper - Posts: 119
Posted: April 22, 2007 at 6:25 PM / IP Logged
I appreciate it.2008 ford escape wiring and bypass - Last Post -- posted image.
mikvot
Gold - Posts: 1,043
Posted: May 04, 2007 at 9:12 PM / IP Logged
Sorry man, my customer flaked on me.....finally got the car today, let me know if you still need the info. Easy install!
bbtaco
Copper - Posts: 119
Posted: May 04, 2007 at 9:31 PM / IP Logged
Thanks for your help. Please post the info you have. Which bypass and RS did you install?
mikvot
Gold - Posts: 1,043
Posted: May 05, 2007 at 3:53 PM / IP Logged
12 v blue/red at ignition harness (+)
ignition WHITE/ orange at same (+)
acc. violet/green at same (+)
starter  lt.blue/white at same (+)
brake violet/white at brake switch (+)
lock lt.blue /green at drivers kick (-)
unlock yellow/violet at same (-)
door trigger grey/violet at same (+)
lock motor grey/brown at same (+)
unlock motor lt. blue green at smae (+)
disarm defeat  violet/grey in drivers door sill where harness t's under drivers seat (+)
park lights violet /white at same (+)
I used the keyoveride sl2 by Fortin for the bypass, and the system was a ca-410a by code alarm, which works with the factory keyfobs.
Also, i didn't use a tach wire for the install, cuz the vehicle already has factory antigrind, but i'm sure the wire can be found at any fuel injector.
park lights
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
