2006 Dodge Magnum SRT8 Alarm Wiring
Welcome Guest :)
airride2
Member -
Posted: April 21, 2007 at 7:44 AM / IP Logged
Without Nav, looking for stereo/alarm wiring. Would like to put in a compustar with remote starter if possible.
KarTuneMan
Platinum -
Posted: April 21, 2007 at 10:17 AM / IP Logged
12 VOLTS | Lt.Blue/red | Ignition switch harness | + |
IGNITION | Pink/white | Ignition switch harness | + |
IGNITION 2 | Violet/tan | Ignition switch harness | |
| | Second IGN is ground through 600-omhs and Second START is ground through 180-ohms. Refer to the supplied diagram for exact wiring instructions. |
ACCESSORY | Runs with Ignition | | |
STARTER | Pink/green | Ignition switch harness | + |
STARTER 2 | Violet/tan | Ignition switch harness | |
KEY SENSE | Violet/orange | At ignition switch | + |
| | Wire goes to pin C2-8 of instrument cluster module. Resistance at ignition switch varies with key in or out. |
TACH SIGNAL | Blue/w. stripe (3.5L) | At any coil on driver's side of engine | AC |
LOCK | PURPLE / green (300-ohms) | In black plug above p-brake in driver's kick | - |
| | One wire doorlock system. 300-ohms to ground for lock and 100-ohms to ground for unlock. |
UNLOCK | PURPLE / green (100-ohms) | In black plug above p-brake in driver's kick | - |
DOORPIN | SEE NOTES | | |
| | Driver's doorpin is PURPLE, rear left door is PURPLE / GRAY, both located in the black plug above the parking brake. Right front door is PURPLE / WHITE and right rear is PURPLE / YELLOW, both found in a white plug above the passenger kickpanel. |
TRUNK PIN | PURPLE / orange | In passenger kickpanel | - |
TRUNK RELEASE | Violet/tan | At switch below steering wheel on left | - |
FACTORY ARM | Pulse lock and driver's doorpin | | |
FACTORY DISARM | SEE NOTES | | |
| | The factory alarm disarms with the OEM remote or during remote start only. |
BRAKESWITCH | GREEN / WHITE | At switch above brake pedal | + |
| | There are 2 wires of this color at the switch, test carefully. |
PARKLIGHTS | WHITE/ brown | At light switch in dash | - |
| | Ground through 2.4-kOhm resistor to activate parking lights. |
HORN | GREEN/ orange | At horn under hood | + |
REVERSE LIGHTS | WHITE/ lt. green | In passenger kickpanel | + |
VSS WIRE | Dk.GREEN/ brown | At PCM pin C4-32 | |
airride2
Member -
Posted: April 22, 2007 at 1:13 AM / IP Logged
Is it possible to hook up a aftermarket amp/sub to the factory subwoofer wiring?
Wednesday, May 15, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
