2007 chevy express, alarm/remote start
justardnck
Posted: April 21, 2007 at 1:32 PM / IP Logged
I need the wiring diagram for an aftermaket alarm and Passlock wiring and location of module to install a DEI 1700G remote start module
2007 Chevy Express van
thanks
wire4veins
Copper - Posts: 97
Posted: April 22, 2007 at 3:13 PM / IP Logged
Hope this helps, sorry the format is a little tough to read.
EXPRESS VAN              2007
KEY       T-HARNESS       IMMOBILIZER
N/A       N/A       GM's PASSLOCK 2 ANTI-THEFT System, Requires 791 Bypass Module
PART       COLOR       LOCATION
12 VOLT CONST   RED / BLACK (+) IGNITION SWITCH HARNESS
STARTER       YELLOW (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A
IGNITION 1       PINK (+)       IGNITION SWITCH HARNESS
IGNITION 2       WHITE (+) See NOTE *4       IGNITION SWITCH HARNESS
IGNITION 3       N/A
ACCESSORY /HEATER BLOWER 1       ORANGE (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       N/A
KEYSENSE       LIGHT GREEN (-)       IGNITION SWITCH HARNESS
PARKING LIGHTS ( - )       BROWN / WHITE (-)       @ BCM, BROWN Plug, Pin B2, See NOTE *1
PARKING LIGHTS ( + )       BROWN (+)       @ FUSEBOX UNDER DRIVERS SEAT
POWER LOCK       LIGHT BLUE (TYPE B)       @ BCM LIGHT BLUE plug, Pin B5, See NOTE *1
POWER UNLOCK       WHITE (TYPE B)       @ BCM, LIGHT BLUE plug, Pin B10, See NOTE *1
DOOR TRIGGER       See NOTE *2       @ BCM, LIGHT BLUE plug, See NOTE *1
DOMELIGHT SUPERVISION       GRAY/BLACK (+) or DARK BLUE/WHITE (+)       @ BCM, BLACK Plug, Pin E, See NOTE *1
TRUNK RELEASE       N/A
SLIDING POWER DOOR       N/A
HORN       TAN (-)       @ BCM, GRAY Plug, Pin B9, See NOTE *1
TACH       WHITE or PURPLE       @ PCM, GREEN plug, Pin 26, See NOTE *3
WAIT TO START LIGHT       N/A
BRAKE       WHITE (+)       @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       N/A
ANTI-THEFT       YELLOW (+) and BLACK (-) or TAN (-)       GM's PASSLOCK 2 System, these wires exit the Ignition Switch Tumbler together and are in the Main Ignition Switch Harness in the Column.
EXTRA INFORMATION
NOTE *1 The BCM (Body Control Module) is located under the PASSENGER side of the dash, behind the knee bolster. NOTE *2 This vehicle has 3 door triggers, the DRIVERS DOOR is a TAN (-) Pin B4, the PASSENGER DOOR ad REAR CARGO DOOR is a LIGHT GREEN (-) and the REAR DOORS and SLIDING DOOR is a YELLOW/BLACK (-) in Pin A10. When connecting to an ALARM SYSTEM, use all 3 and DIODE ISOLATE. See DIAGRAM NOTE *3 The PCM (Power Control Module) is located on the DRIVERS SIDE FENDER. On the 4.3L engine the TACH wire is WHITE, and on the 4.8L, 5.3L and 6.0L the TACH wire is PURPLE. NOTE *4 IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!!
Information is a reference only. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
"D"
Precision Autosound - Owner
MECP Master Installer
