adding a power door lock switch
b2reptile
Member - Posts: 26
Posted: July 11, 2007 at 4:48 PM / IP Logged
You won't need the door trigger wires at all.  Does your alarm have built in relays for the lock/unlock circuit?  You should have two wires coming off each actuator, which are high current that send 12v+ to move the motors.  Do these wires hook directly to the alarm lock/unlock outputs?  Or is there a seperate relay pack in between the alarm and the actuators?  This will make a big difference on how to connect.
italian_virus
Copper - Posts: 143
Posted: July 11, 2007 at 5:21 PM / IP Logged
hmm ok
i just checked it out
from the actuators
it goes to an all black unit, which i believe could be the relay
then from there it branches off to the other actuator and the alarm
italian_virus
Copper - Posts: 143
Posted: July 14, 2007 at 1:50 PM / IP Logged
PROBLEM SOLVED, i got it too work!!!!!
what i did was, if you look at the diagram
https://img520.imageshack.us/img520/2906/p1050682oo3.jpg
I used the, White 3 pin - Door Lock Port - Blue and Green wires
and the ground from the alarm, connected it to my switch and vola it works, now its just a matter of running the wires and im good to go!
Thanks for the help... i appreciate it!
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
