passlock 2 wirirng, 2000 suburban
anthonylecuona
Copper - Posts: 51
Posted: May 29, 2007 at 5:32 PM / IP Logged
what ar the wire collors for the passlock 2 system and where are they located \
please help thanks
In case of snow drive backwards, instant front wheel drive, then again who needs it when you drive a Scoobie
KarTuneMan
Platinum - Posts: 7,056
Posted: May 29, 2007 at 5:43 PM / IP Logged
What module are you using....you might want to get one that gets signal from the OBD2 connector.
R code is yellow, common is ORANGE / black
anthonylecuona
Copper - Posts: 51
Posted: May 29, 2007 at 6:54 PM / IP Logged
i am using the directed 556L bypass module
KarTuneMan
Posted: May 29, 2007 at 7:05 PM / IP Logged
I am not a DEI guy. I don't know their part #'s
enice
Silver - Posts: 857
Posted: May 29, 2007 at 7:30 PM / IP Logged
Passlock 2 wires are in the small three-wire harness(with RED / white[or solid white], ORANGE / black[or solid black]  and yellow wires) coming off the back of the key cylinder.  It seems according to the 556L manual that the yellow wire would be cut and run in series with the yellow and yellow/black wires (from the 556L)   This method is also done using a relay in case you dont have a bypass module.  As for the black wire(from the 556L) you would tag it to the ORANGE / black wire or solid wire(whichever is there) Good Luck
anthonylecuona
Copper - Posts: 51
Posted: May 29, 2007 at 7:38 PM / IP Logged
i have
black- passlock ground
pink- ignition input
blue- status input
red-12v +
yellow- key sude resistance in
black yellow- vehicle resistance out
does that mean run the yellow to the key cylinder side of the cut and the black yellow on the other side?
and the passlock ground for the solid black on the three wire harness of the column?
hope you can tell me thanks
enice
Silver - Posts: 857
Posted: May 29, 2007 at 7:49 PM / IP Logged
yes exactly what I mentioned in the PM
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
