amp wiring??
kadman23
Member - Posts: 27
Posted: February 14, 2003 at 2:03 PM / IP Logged
i have a 600w jensen 4 channel amp and am hooking up some subs to it.  the subs are 4 ohms and i want to know the best way to hook them up without toasting my amp!  the amp is bridgable and right now i have it wired as such,
The 2 10" 4ohm subs are wired together then a single + and - wire is ran to the amp and it is bridged. is there a better way???  here is a sort of a pic of how it is wired!
any suggestions or coments welcome and a greatly appreciated!!!!!!!!!   :)
 to sub     ---------------------to - amp wire
 to sub     ++++++++++++to + amp wire   +++++++++++++++  to amp,  Bridged
 to sub     ---------------------to + amp wire   ---------------------------  to amp, Bridged
 to sub     ++++++++++++to - amp wire
Kadman
kadman23
Member - Posts: 27
Posted: February 14, 2003 at 2:05 PM / IP Logged
another ?  for u all can u explain  series and parallel hook up to me and which is better?????????
Thank you!!!!
Kadman
demond96
Member - Posts: 41
Posted: February 14, 2003 at 4:16 PM / IP Logged
amp wiring?? - Last Post -- posted image.parallel= all like terminals wired together.( positive to positive, negative to negative) then to like terminals on the amp.
     series=    all terminals wired in a string, amp positive to sub(1) positive. Sub(1) negative to sub(2) positive. Sub(2) negative to amp negative.
In series (2)4ohm subs will give you a 8ohm load. In parallel (2)4ohm subs will give you a 2ohm load. That is if you have single voice coil subs.If your amp is rated at 4ohms it will not handle a parallel wireing configuration. So you would be alot safer to wire it in a series.
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
