front right speakers very quiet?
jmelton86
Gold - Posts: 1,228
Posted: July 11, 2007 at 10:30 PM / IP Logged
Alright, now do like stevdart suggested and use some other RCA cables. You don't need to route them yet as you're just testing to see if they're the culprits. If the sound is still weak then your stereo is defective. If so, just run both front and rear channels on the amp from the rear RCA outputs from the stereo (using RCA y-cables). The fader at this point would be the gains on the amp. Balance will still be retained.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
ryan h
Member - Posts: 10
Posted: July 12, 2007 at 12:26 AM / IP Logged
Alright, I got the head unit out finally without buying those stupid keys and without damage, thankfully.  I was able to take some trim off and depress the tabs that hold it into the tray.  Anyway, I reset the wires back to how they should be, and then noted which speakers/jacks are working.  I then swapped those jacks to the non working speakers both on the head unit and amp.  The non working speakers then worked perfect on the RCA ports that shouldn't have worked if the head unit was faulty.  I suppose that narrows it down to the RCA cables!  Thank you all very much for your help!  I really appreciate everyone who uses this forum and adds useful information to it, this has been a lifesaver!
haemphyst
Platinum - Posts: 5,059
Posted: July 12, 2007 at 10:33 AM / IP Logged
bigbangs wrote:
The polarity is reversed. Check to make sure you have the positive going to the positive of the speaker and the negative going to the negative
Ummm... Yeah, NO! That's NOT the issue. I just read this entire thread, but that was not the issue, ever. Reversing the leads on a speaker WILL NOT cause what was described.
Wednesday, February 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
