clutch wire on an 05 lancer
newinstaller
Copper - Posts: 160
Posted: July 27, 2007 at 9:23 PM / IP Logged
anyone have info on a clutch wire on an 05 lancer
KarTuneMan
Platinum - Posts: 7,056
Posted: July 28, 2007 at 12:43 AM / IP Logged
What type of info are you needing?
xtremej
Gold - Posts: 1,440
Posted: July 28, 2007 at 12:59 PM / IP Logged
Blue/Orange its type 4 is what I am  showing.
KarTuneMan
Posted: July 29, 2007 at 8:17 AM / IP Logged
TYPE 4
A wire at the clutch must be opened during crank to
engage the starter. Pin 86 goes to the starter wire and
pin 85 to a ‘ground when running’ output from your
remote starter.  Your clutch wire gets cut. the switch side goes to 87a, the other side to 30. You "MIGHT" also need to connect the starter wire at the harness as well!
Wednesday, May 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
