2001 mazda 626 wiring
Welcome Guest :)
wcrstereo
Member -
Posted: February 16, 2003 at 5:48 PM / IP Logged
Has anyone put an alarm into a 2k1 626?
Moderator -
Posted: February 16, 2003 at 5:56 PM / IP Logged
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|black (x2) |+ |ignition harness || STARTER|green |+ |ignition harness || IGNITION|BLACK/ white |+ |ignition harness || SECOND IGNITION|BLACK/ red |+ |ignition harness || ACCESSORY|blue |+ |ignition harness || POWER LOCK|BROWN / yellow |- |*2 || POWER UNLOCK|white & brn/wht *3 |- |*2 || LOCK MOTOR|green | |drivers kick panel || UNLOCK MOTOR|pink | |drivers kick panel || DISARM DEFEAT|red | |passengers kick panel || PARKING LIGHTS +|WHITE/ red | |green plug at fuse box || PARKING LIGHTS -|lt GREEN/ red | |headlight switch || HEADLIGHTS|yellow |- |headlight switch || DOOR TRIGGER|RED / white |- |green plug at fuse box || DOME SUPERVISION|use door trigger | | || TRUNK/HATCH PIN|WHITE/ black |- |at light in trunk *5 || HOOD PIN| | | ||TRNK/HTCH RELEASE|orange |- |*2 || FCTRY ALARM ARM| | | ||FCTRY ALRM DISARM| | | || DISARM NO UNLOCK|*4 | | || TACHOMETER|*1 | |ignition coil || SPEED SENSE|gray/blue | |instrument cluster or ECM *6|| BRAKE WIRE|purple |+ |brake pedal switch || HORN TRIGGER|grn/red or grn/org |- |steering column || WIPERS|blu/wht(L),blu/red(H|+ |steering column || LF WINDOW UP/DN|red - RED / blu |A |drivers window switch || RF WINDOW UP/DN|grn/wht - RED / blk |A |drivers switch or kick panel|| LR WINDOW UP/DN|blu/wht - blu/blk |A |drivers switch or kick panel|| RR WINDOW UP/DN|grn/yel - wht/red |A |drivers switch or kick panel|Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. See direct fax document #1061. *1 Use red or green for the 4 cylinder and white for the 6 cylinder. *2 Found at two tan modules near the hood release. *3 The white wire will unlock the drivers door only, and the BROWN / white will unlock the other doors. use both wires and diode isolate each. *4 To disarm with out unlocking, send a positive trigger to the blue / YELLOW key sense wire. The key sense wire is located at the steering column. *5 Can also find in drivers kick panel in the harness from the rear if the vehicle has a factory alarm. *6 The ECM is under the center console. The VSS wire is in pin 58.Jeff
Saturday, May 18, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
