stereo wiring for dodge nitro
Welcome Guest :)
dream sound
Member -
Posted: September 15, 2007 at 3:43 AM / IP Logged
i need a stereo wiring diagram and a wiring diagram for a remote starter and security and i need a remote start wiring diagram for a 01 nissan maxium can somebody please help me? thank you very much
KarTuneMan
Platinum -
Posted: September 15, 2007 at 7:19 PM / IP Logged
Maxima
Nitro securrity. Audio
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
| | This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available for remote start installations, contact your supplier to find out. If one of these modules is not available to you, refer to our transponder bypass diagram. |
12 VOLTS | Red | Low in driver's kickpanel | + |
IGNITION | Pink/white | Ignition switch harness | + |
ACCESSORY | Violet/brown | Ignition switch harness | mux |
| | Required ground through a 600-ohm resistor to activate accessories. See the provided diagram. |
STARTER | Violet/brown | Ignition switch harness | mux |
| | Required ground through a 180-ohm resistor to activate starter. See the provided diagram. |
TACH SIGNAL | Opposite from BROWN / gray | At any of the coils on the engine | AC |
FUEL INJECTOR | Opposite from BROWN / white | At any of the fuel injectors on the engine | AC |
LOCK | Violet/green | DKP harness from driver's door | - |
| | Requires a 1-kohm resistor to lock and a 185-ohm resistor to unlock. |
UNLOCK | Same wire as lock | DKP harness from driver's door | - |
DOORPIN | SEE NOTES | | |
| | Driver's door - Violet/blue, front right door - Violet/white, rear left door - Violet/gray, and right rear door - Violet / YELLOW. All 4 wires are located in the black plug on the left side of the steering column. |
HOODPIN | Violet/blue | At pinswitch under hood | - |
TRUNK PIN | Violet/orange | In black plug on left side of steering column | - |
TRUNK RELEASE | Lt.GREEN/ blue | In driver's kickpanel running to rear of vehicle | Rev Pol |
| | This will only unlock the trunk lid. |
FACTORY ARM | Pulse lock & LF doorpin | | |
FACTORY DISARM | Through OEM remote only | | |
BRAKESWITCH | Dk.GREEN / WHITE | Large harness low in driver's kickpanel | + |
PARKLIGHTS | WHITE/ violet | Large harness low in driver's kickpanel | + |
HAND BRAKE | GREEN / WHITE | At switch on handbrake lever | - |
HORN | Dk.GREEN/ violet | At steering column | - |
VSS WIRE | GREEN/ brown | In Green plug at PSM on pass. side fender under hood | AC |
Saturday, May 18, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
