2007 hummer h2, remote start wiring
uwDawson
Member - Posts: 7
Posted: September 27, 2007 at 11:51 AM / IP Logged
I need wiring diagram for 07 hummer h2, remote start.  thanks
kola7126
Copper - Posts: 93
Posted: September 27, 2007 at 12:47 PM / IP Logged
 MODEL YEAR(S)
 H2  2003 -2006
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   Has NEW PASSLOCK II Anti-Theft System, Requires Part #XK06 Module
 PART  COLOR LOCATION DIAGRAM
 12 VOLT CONSTANT  RED (+) and RED / WHITE (+)   @ IGNITION SWITCH HARNESS
 STARTER YELLOW (+)  @ IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 PINK (+)  @ IGNITION SWITCH HARNESS
 IGNITION 2 WHITE (+)  @ IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 ORANGE (+)  @ IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 BROWN (+)  @ IGNITION SWITCH HARNESS
 KEYSENSE N/A
 PARKING LIGHTS ( - ) GRAY/BLACK (-)  @ BCM. BROWN Plug, Pin B2, See NOTE *1
 PARKING LIGHTS ( + ) BROWN (+) Left and BROWN / WHITE (+) Right, will require both! See NOTE *2  in DRIVERS KICK PANEL, Harness to Rear of Vehicle, See DIAGRAM   26500_H2_DUAL PARKING LIGHT DIAGRAM.pdf
 POWER LOCK LIGHT BLUE (TYPE B)  @ BCM, PURPLE Plug, Pin B3, See NOTE *1
 POWER UNLOCK WHITE (TYPE B)  @ BCM, PURPLE Plug, Pin B2, See NOTE *1
 LOCK MOTOR WIRE GRAY (TYPE C)  @ DRIVERS DOOR Module, in Drivers Door
 DOOR TRIGGER See NOTE *3  See NOTE *3   17044_H2_(-) NEGATIVE DOOR PIN ISOLATION CIRCUIT.pdf
 DOMELIGHT SUPERVISION GRAY/BLACK (+)  @ BCM, BLACK Plug, Pin E, See NOTE *1
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLACK / YELLOW to BLACK (-)  @ HORN Switch or BCM, GRAY Plug, Pin B9, See NOTE *1
 TACH WHITE (1-6Volts AC) testing voltage  @ PCM, GREEN Plug, Pin 10, See NOTE *4
 WAIT TO START LIGHT N/A
 BRAKE WHITE (+)  @ Switch above BRAKE Pedal
 FACTORY ALARM DISARM  LIGHT GREEN (-)  in DRIVERS DOOR at DOOR Module
 ANTI-THEFT GM'S New PASSLOCK II System, Requires XK06 Bypass Module
NOTES
 NOTE *1 The BCM is located behind the HEADLIGHT Switch. The BCM has 6-Plugs, with the PURPLE Plug on the Back of the Module.
NOTE *2 This vehicle has 2 (+) Positive Parking Light wires, use both, requires 2 extra Relays Part 775 to connect See DIAGRAM
NOTE *3 the DRIVERS DOOR is a GRAY/BLACK (-) at the DRIVERS DOOR module in the DRIVERS DOOR. The PASSENGER DOOR is a BLACK/ WHITE (-) at the PASSENGERS DOOR module in the PASSENGERS DOOR. The DRIVERS REAR DOOR is a LIGHT BLUE/BLACK (-) Pin A3 and the PASSENGERS REAR DOOR is a LIGHT GREEN/ BLACK (-) Pin A2, both are located at the BCM, PURPLE plug. When connecting to an ALARM SYSTEM use all 4 wires and DIODE ISOLATE, See DIAGRAM
NOTE *4 The PCM is located under the Hood of the vehicle, on the Drivers side next to the Battery.
uwDawson
Member - Posts: 7
Posted: September 27, 2007 at 2:06 PM / IP Logged
THanks!
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
