2003 ford expedition 5.4l
meh66
Copper - Posts: 266
Posted: October 23, 2007 at 8:11 AM / IP Logged
Does anyone know the color of the RAP disable wire on this vehicle?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
swerks
Copper - Posts: 224
Posted: October 23, 2007 at 8:17 AM / IP Logged
you have to open the drivers doorpin (BLACK / YELLOW) with a relay triggered by a pulse after shutdown the wire can be found in the drivers door bot or at the keyes module behind the glove box
Steve Sverdahl
Swerksound Auto Electric
Red Deer Alberta
meh66
Copper - Posts: 266
Posted: October 23, 2007 at 9:12 AM / IP Logged
I am assuming since you said relay triggered, the BLACK / YELLOW wire is expecting a positive pulse. I know what they say about assuming..LOL. Thanks for your help.
MEH66
KarTuneMan
Platinum - Posts: 7,056
Posted: October 23, 2007 at 9:19 AM / IP Logged
The wire in questing doesn't need to "see" anything.... it's simply needs to be "opened" with the relay.
Cut the wire, one end to pin 87a, the other to 30, then wire the relay with the pulse after shut down output from your unit. Nothing on pin 87
The objective here it to cut, or break, the door pin wire. to simulate (kind of) the door being opened.
meh66
Copper - Posts: 266
Posted: October 23, 2007 at 10:57 AM / IP Logged
Thanks Kar TuneMan..I understand now.
MEH66
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
