resistance, crimp style vs screw type
radioflyer
Copper - Posts: 63
Posted: October 25, 2007 at 9:47 AM / IP Logged
Is there any difference in the conductivity of a crimp style terminal versus a screw type? (amperag in question is >70 amps)
thanks in advance
you can never have too much of a good thing
fakepete
Copper - Posts: 99
Posted: October 25, 2007 at 2:33 PM / IP Logged
A properly installed crimp terminal is almost always more secure than a screw terminal. I am guessing you're talking about the setscrew type terminals. They have a tendency to work loose over time. The crimp terminal should conduct better because there is more even pressure over the whole terminal, as opposed to the setscrew type where the pressure is only under the screw. An overtightened screw can also damage the wire and tear off some of the strands. Unfortunately most distro blocks and amps come with setscrew terminals, so the opportunity to use crimps is limited.
radioflyer
Copper - Posts: 63
Posted: October 25, 2007 at 3:44 PM / IP Logged
Excellent. That's the info I need. Now I can save money too because they're less expensive.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
