2008 escalade, alarm wiring?
stevet
Member - Posts: 36
Posted: October 29, 2007 at 10:12 PM / IP Logged
Need wiring information for alarm install, anyone done one? or could you post wiring info?
Thanks in advance.
init
Copper - Posts: 93
Posted: October 29, 2007 at 11:12 PM / IP Logged
 Battery RED / BLACK (+) AT VEHICLE FUSE BOX
 Ignition 1 PINK (+) IGNITION SWITCH HARNESS
 Starter 1 YELLOW/BLACK (+) AT ECM MODULE BEHIND DRIVER HEADLIGHT
 All Door Trigger GRAY/BLACK (-) AT COURTESY LIGHT UNDER DASH
 Domelight Super GRAY (+) AT BCM MODUEL UNDER DRIVER DASH
 LF Latch BROWN (-) AT DRIVER DOOR MODULE IN DRIVER DOOR
 RF Latch BLACK/ WHITE (-) AT PASSENGER DOOR MODULE IN PASSENGER DOOR
 LR Latch LIGHT BLUE/BLACK (-) AT BCM MODULE UNDER DRIVER DASH
 RR Latch LIGHT GREEN/ /BLACK (-) AT BCM MODULE UNDER DRIVER DASH
 Trunk Trigger PINK/BLACK (-) AT BCM MODULE UNDER DRIVER DASH
 Hood Trigger PINK/BLACK (-) AT BCM MODULE UNDER DRIVER DASH
 Alarm Disarm LIGHT GREEN (-) AT MODULE IN DRIVERS DOOR
 Parking Lights LIGHT BLUE (-) AT BCM MODULE UNDER DRIVER DASH
I'm not a professional installer. But I did stay at a Holiday Inn Express.
kola7126
Copper - Posts: 93
Posted: October 31, 2007 at 3:28 PM / IP Logged
 MODEL YEAR(S)
 ESCALADE  2007 -
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   GM's PASSKEY 3 TRANSPONDER ANTI-THEFT SYSTEM Requires 791 Bypass Module and Ignition Key
 PART  COLOR LOCATION
 12 VOLT CONSTANT  (2) RED / BLACK (+)   @ FUSE BOX
 STARTER WHITE (+) See NOTE *1  @ IGNITION SWITCH HARNESS or BCM, LIGHT GREEN Plug, Pin 4 See NOTE *2
 STARTER 2 N/A
 IGNITION 1 PINK (+)  @ IGNITION SWITCH HARNESS or BCM, LIGHT GREEN Plug, Pin 14 See NOTE *2
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BROWN (+)  @ IGNITION SWITCH HARNESS or BCM, LIGHT GREEN Plug, Pin 21 See NOTE *2
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) LIGHT BLUE (-)  @ HEAD LIGHT Switch or BCM, NATURAL Plug, Pin 8 See NOTE *2
 PARKING LIGHTS ( + ) BROWN (+) Left and BROWN (+) Right See DIAGRAM  @ UNDER HOOD FUSE BOX, BLACK 30-Pin Plug
 POWER LOCK No Information at this time!!
 POWER UNLOCK No Information at this time!!
 DOOR TRIGGER See NOTE *3
 DOMELIGHT SUPERVISION GRAY (+)  @ BCM, NATURAL Plug, Pin 5 See NOTE *2
 TRUNK RELEASE PINK (-) Glass and GRAY (-) Gate See NOTE *4  @ BCM, PINK Plug, Pins 24 and 13 See NOTE *2
 SLIDING POWER DOOR N/A
 HORN TAN (-)  @ HORN Switch or BCM, BROWN Plug, Pin 18 See NOTE *2
 TACH NOT PINK, BROWN or BLACK  @ ANY FUEL-INJECTOR or IGNITION COIL
 WAIT TO START LIGHT N/A
 BRAKE LIGHT BLUE/WHITE (+)  @ SWITCH ABOVE BRAKE or BCM, BROWN Plug, Pin 6, See NOTE *2
 FACTORY ALARM DISARM  LIGHT GREEN (-)  @ DRIVERS DOOR MODULE, BROWN 16-Pin Plug, Pin 4
 ANTI-THEFT GM's PK3 TRANSPONDER ANTI-THEFT SYSTEM, Requires 791 and Extra Programmed Ignition Key  @ IGNITION SWITCH TUMBLER
 EXTRA INFORMATION
 NOTE *1 The STARTER 1 wire, requires a (+) POSITIVE thru a 1300 OHM Resistor to Start See DIAGRAM. NOTE *2 The BCM (Body Control Module) is located to the LEFT of the STEERING COLUMN. NOTE *3 The DRIVERS DOOR TRIGGER is a GRAY/BLACK (-) at the DRIVERS DOOR MODULE in the DRIVERS DOOR, BROWN 16-Pin Plug, Pin 13, the PASSENGER DOOR TRIGER is a BLACK/ WHITE (-) at the PASSENGER DOOR MODULE in the PASSENGER DOOR, BROWN 16-Pin Plug, Pin 13. The DRIVERS REAR DOOR TRIGGER is a LIGHT BLUE/BLACK (-) PINK Plug, Pin 15 and the PASSENGER REAR DOOR TRIGGER is a LIGHT GREEN/ BLACK (-) PINK Plug, Pin 14 both wires are located in the PINK Plug on the BCM, when connecting to an ALARM SYSTEM use all (4) FOUR wires and DIODE ISOLATE, See DIAGRAM. NOTE *4 TEST these wires while OPENING the LIFTGLASS and LIFTGATE from the HANDLE on the REAR HATCH of the vehicle.
NowYaKnow
Gold - Posts: 1,217
Posted: November 01, 2007 at 8:02 AM / IP Logged
Not much to post most of what you need is done through the doorlock/alarm interface.
Mike
