2007 dodge nitro rs
mrjc480
Member - Posts: 44
Posted: November 03, 2007 at 6:46 PM / IP Logged
Does this vehicle need a remote start bypass?  The vehicle will start but stall after 5 seconds but if I turn the key on  and start with the remote then remove the key it will stay started.  It also seems that the ac/heater is on the ignition wire however it turns off during cranking but the wire (pink/white) stays 12v during cranking.  Any help????
Im moving to MEXICO and Im not speaking spanish!
Moderator - Posts: 12,488
Posted: November 03, 2007 at 7:38 PM / IP Logged
This does require a bypass module as well it sounds as though your tach is not properly programmed.
mrjc480
Member - Posts: 44
Posted: November 03, 2007 at 8:03 PM / IP Logged
I tested each coil and it was roughly 35vac.  I thought a tach signal should be 1-5vac?
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
