2008 Toyota Camry Alarm/Remote Start/Stereo Wiring
lex305
Member - Posts: 8
Posted: November 25, 2007 at 5:20 PM / IP Logged
Does any1 have the alarm wiring for this car?
lex
Twelvoltz
Platinum - Posts: 2,384
Posted: November 25, 2007 at 7:11 PM / IP Logged
Audiovox Lists:
          #513592: 2008 TOYOTA CAMRY 4DR SEDAN WITH 2.4L ENGINE AND JBLŽ 8-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLUE & BLUE YELLOW          (+)          RADIO HARNESS
     Accesory          GRAY          (+)          RADIO HARNESS
     Ground          BROWN          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          RADIO HARNESS
     Power Antenna          ORANGE          (+)          RADIO HARNESS
     Amp Turn On
               THE AMPLIFIER TURNS ON WITH THE ACCESSORY POWER IN THE VEHICLE
     LF Speaker (+)          BLACK
               THESE WIRES PROVIDE THE AUDIO INPUT TO THE AMPLIFIER
     LF Speaker (-)          WHITE
     RF Speaker (+)          RED
     RF Speaker (-)          GREEN
     Amp Location          UNDER THE FRONT RIGHT SEAT
     Steering Cntrls          YES
     Speed Cntrl          YES
     Radio Security          YES
     Security
     Battery          BLACK          (+)          IGNITION SWITCH HARNESS
     Ignition 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BROWN          (-)          AT VEHICLE FUSEBOX
     Domelight Super          BROWN          (-)          AT VEHICLE FUSEBOX
     LF Latch          BLUE          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     RF Latch          YELLOW          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     LR Latch          LIGHT GREEN          (-)          AT VEHICLE FUSE BOX
     RR Latch          GRAY          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Trunk Trigger          WHITE          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Hood Trigger          RED          (-)          AT VEHICLE HOOD PIN SWITCH
     Alarm Disarm          BLUE          (-)          INGITION SWITCH HARNESS
     Parking Lights          BLACK          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     Convenience
     Headlights-Lo          PINK          (-)          AT BECU MODULE IN VEHICLE FUSEBOX
     All Hazrd Lights          WHITE          (-)          AT VEHICLE HAZARD SWITCH
     Wipers-Lo          PINK          (+)          AT WIPER CONTROL SWITCH
     Wipers-Hi          GREEN          (+)          AT WIPER CONTROL SWITCH
     Parking Brake          YELLOW          (-)          AT PARKING BRAKE SWITCH
               MAY ALSO BE BLUE ON SOME MODELS
     Trnk Release          BLACK          (REV)          AT BECU MODULE IN VEHICLE FUSEBOX
     Remote Start
     Ignition 2          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          WHITE          (+)          IGNITION SWITCH HARNESS
     Starter 2          GRAY          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE          (-)          IGNITION SWITCH HARNESS
               THIS WIRE WILL DISARM THE FACTORY SECURITY WITHOUT UNLOCKING THE DOORS
     Tachometer          BLACK          (AC)          AT DATALINK CONNECTOR UNDER DRIVER DASH
     Speed Sense          VIOLET          (AC)          RADIO HARNESS
               ALSO AT AMPLIFER UNDER PASSENGER SEAT
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED          (+)          IN HARNESS IN DRIVER KICKPANEL
     Horn          WHITE          (-)          AT VEHICLE FUSE BOX
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          GRAY          (-)          IN HARNESS IN DRIVERS KICKPANEL
               USE A DOUBLE PULSE TO UNLOCK ALL DOORS
     PowerLock          BROWN          (-)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          GREEN          (REV)          AT DRIVER WINDOW SWITCH
     LF Window Dn          BROWN          (REV)          AT DRIVER WINDOW SWITCH
     RF Window Up          WHITE          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RF Window Dn          RED          (REV)          IN HARNESS IN DRIVER KICKPANEL
     LR Window Up          BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL
     LR Window Dn          BLACK          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RR Window Up          YELLOW          (REV)          IN HARNESS IN DRIVER KICKPANEL
     RR Window Dn          LIGHT GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL
     Sunroof Open          BROWN          (-)          AT SUNROOF CONTROL SWITCH
     Sunroof Close          BLUE          (-)          AT SUNROOF CONTROL SWITCH
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
