2008 subaru legacy remote start
autoneon
Member - Posts: 10
Posted: December 28, 2007 at 6:51 AM / IP Logged
can anyone help with the clutch???
tedmond
Gold - Posts: 4,610
Posted: December 28, 2007 at 10:10 AM / IP Logged
neg or positive clutch? if its postive, connect your start wire to the wire that shows 12v when clutch it pressed. if its a negative, wire up a relay.
85 - constant 12v
86 - ground out when running
87 - ground
30 - to wire that shows ground when clutch pressed.
autoneon
Member - Posts: 10
Posted: December 31, 2007 at 9:16 AM / IP Logged
ok...I got everything figured out
the R/S worked a few times...
now it does not work anymore...when I turn on the car, the led's stay on constantly...read the manual and states it's in service mode...tried to take it out of service mode or reprogram but nothing...the parking lights stay on all the time now even when the car is shut off..checked all the connections and everything is good...
when I press the buttons on the transmitters, the led's just blink constantly
someone please help...is the R/S unit defective??  Ultra Start 1256M
Thanx
autoneon
Member - Posts: 10
Posted: January 02, 2008 at 9:12 AM / IP Logged
I know there's someone here who knows what I am talking about
I hope???????????
JWorm
Platinum - Posts: 2,208
Posted: January 02, 2008 at 6:48 PM / IP Logged
Back when I installed Ultrastart I saw a lot of units go into service mode and then would not come out of it. Swapping the antenna and antenna cable would fix the problem. Either that, or you are not trying to take it out of service mode using the correct procedure. How are you attempting to do it?
Monday, June 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
