Wire codes for a 2001 Golf GTI 1.8T?
shebal
Member - Posts: 17
Posted: February 23, 2003 at 9:12 PM / IP Logged
Was wondering if anyone had wire codes for a 2001 Golf GTI 1.8T?
camino
Copper - Posts: 54
Posted: February 25, 2003 at 7:19 PM / IP Logged
for the one with power windows use this
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness            |
|          STARTER|RED / gray            |+ |ignition harness            |
|        IGNITION|black               |+ |ignition harness            |
|        ACCESSORY|BLACK/ red           |+ |ignition harness            |
|       POWER LOCK|yellow/blue        |- |drivers door module *1      |
|     POWER UNLOCK|GREEN/ red *2        |- |drivers door module *1      |
|       LOCK MOTOR|purple / YELLOW       |   |drivers door module *1      |
|     UNLOCK MOTOR|blue / YELLOW        |   |drivers door module *1      |
|    DISARM DEFEAT|pur/yel or blu/yel |   |passengers door module *3   |
| PARKING LIGHTS +|gry/red & gry/blk   |   |drivers kick panel          |
|       HEADLIGHTS|yellow/red          |+ |headlight switch            |
|     DOOR TRIGGER|blue/gray *4        |- |comfort module *5           |
| DOME SUPERVISION|blue/gray           |- |comfort module *5           |
| TRUNK/HATCH PIN|brn/blk or brn/blu |- |hatch light                 |
|        HOOD PIN|BROWN / red           |- |comfort module *5           |
|TRNK/HTCH RELEASE|BROWN / black        |- |comfort module *5           |
| FCTRY ALARM ARM|arms w/ lock        |   |                            |
|FCTRY ALRM DISARM|disarms w/ unlock   |   |                            |
|       TACHOMETER|*6                  |   |ignition coil               |
|      SPEED SENSE|                    |   |                            |
|       BRAKE WIRE|RED / black           |+ |drivers kick panel          |
|     HORN TRIGGER|BLACK / YELLOW        |+ |comfort module *5           |
|           WIPERS|grn/yel and green   |+ |wiper motor                 |
| LF WINDOW UP/DN|*7                  |   |                            |
| RF WINDOW UP/DN|*7                  |   |                            |
| SUN RF OPN/CLOSE|*7                  |   |                            |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
| RADIO ILLUMINATE|                    |   |                            |
|    POWER ANTENNA|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 The drivers door module is located in the drivers door. *2 A double pulse will unlock all doors and disarm the factory alarm. *3 The passengers door module is located in the passengers door. *4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are BROWN / white and are all located in their own door at their own door module. *5 The comfort module is the main control module located under the drivers side of the dash.    *6 The 4 cylinder tach wire is green with a stripe. The 6 cylinder tach is either purple with a stripe, or black with a stripe.    *7 The windows can be rolled up and the sunroof closed by extending the door lock pulse. DEI recommends that you only use a validity channel to roll up the windows.
and wiyhout power windows is this:
|       POWER LOCK|yellow/blue        |- |comfort module *2           |
|     POWER UNLOCK|YELLOW /GREEN *1     |- |comfort module *2           |
|       LOCK MOTOR|purple / YELLOW       |   |comfort module *2           |
|     UNLOCK MOTOR|blue / YELLOW        |   |comfort module *2           |
|    DISARM DEFEAT|pur/yel or blu/yel |   |comfort module *2           |
|     DOOR TRIGGER|*3                  |- |comfort module *2           |
| DOME SUPERVISION|blue/gray           |- |comfort module *2           |
|        HOOD PIN|BROWN / red           |- |comfort module *2           |
|TRNK/HTCH RELEASE|BROWN / black        |- |comfort module *2           |
|       TACHOMETER|*4                  |   |ignition coil               |
|      SPEED SENSE|                    |   |                            |
|     HORN TRIGGER|BLACK / YELLOW        |+ |comfort module *2           |
|        RADIO 12V|                    |   |                            |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|                    |   |                            |
|       LF SPEAKER|                    |   |                            |
|       RF SPEAKER|                    |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 A double pulse will unlock all doors and disarm the factory alarm. *2 The comfort module is the main control module located under the drivers side of the dash.   *3 There are 2 separate door trigger wires in this car. Use both and diode isolate each. The drivers door is BROWN / yellow, and the passenger door is BROWN / purple. *4 The 4 cylinder tach wire is green with a stripe. The 6 cylinder tach is either purple with a stripe, or black with a stripe.
shebal
Member - Posts: 17
Posted: February 26, 2003 at 8:19 AM / IP Logged
Thanks Camino.
camino
Copper - Posts: 54
Posted: February 26, 2003 at 4:38 PM / IP Logged
no problem,any quiestion,just let us know.
Friday, June 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
