2007 Honda Fit Alarm/Remote Start Wiring
crank71
Member - Posts: 18
Posted: October 22, 2006 at 10:38 PM / IP Logged
Looking for a wiring diagram for a 2007 Honda Fit to install a remote starter with locks....thanks.
Mike M2
Platinum - Posts: 2,652
Posted: October 23, 2006 at 7:06 AM / IP Logged
12volts white (50A)  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow/black  +  ignition harness
Second Accessory WHITE/ red  +  ignition harness
Keysense GREEN / WHITE  -  ign harn or GCM, 40 pin plug, pin 11
Notes: The GCM (Gauge Control Module) is incorporated in the instrument cluster.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 8.
Power Lock WHITE/ green  -  dr kick or GCM, 40 pin plug, pin 9
Power Unlock WHITE/ blue  -  dr kick or GCM, 40 pin plug, pin 10
Lock Motor WHITE/ black  5wi fuse box, green 8 pin plug, pin 2
Unlock Motor yellow/black  5wi fuse box, green 8 pin plug, pin 5
Parking Lights+ RED / black  +  fuse box, 14 pin plug, pin 5
Parking Lights- blue  -  switch or GCM, 40 pin plug, pin 19
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 5.
Hazards same as turn signal wires
Turn Signal(L) GREEN/ red  +  switch or GCM, 20 pin plug, pin 6
Turn Signal(R) GREEN/ YELLOW  +  switch or GCM, 20 pin plug, pin 5
Reverse Light GREEN/ black  +  fuse box, 14 pin plug, pin 9
Door Trigger green (D), purple (P)  -  kick or GCM, 20 pin plg, pins 14, 13
Notes: Use both wires and diode isolate each.
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pins 20 and 9.
Dome Supervision GREEN/ red  -  fuse box or GCM, 20 pin plug, pin 12
Trunk/Hatch Pin GREEN/ red  -  dr kick or GCM, 20 pin plug, pin 16
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 20 pin plug, pin 7.
Hood Pin GREEN/ black  -  pin sw or SCU, 20 pin plug, pin 18
Notes: The SCU (Security Control Unit) is under the driver side dash.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm WHITE/ red  -  dr kick or SCU, 20 pin plug, pin 4
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm white  -  dr kick or SCU, 20 pin plug, pin 3
Disarm No Unlock see factory alarm disarm
Tachometer GREEN/ orange  ac  fuse box, 6 pin plug, pin 2
Notes: Can also go to any fuel injector and use the wire that is NOT yellow/black.
Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Wait to start N/A
Brake Wire WHITE/ black  +  sw or fuse box, 14 pin plug, pin 4
Parking Brake GREEN/ orange  -  switch or GCM, 40 pin plug, pin 3
Horn Trigger orange  -  switch or GCM, 14 pin plug, pin 8
If equipped, also found at the SCU (Security Control Unit) under the driver side dash, 16 pin plug, pin 2.
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2007 Honda Fit Alarm/Remote Start Wiring -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Mike M2
Tech Manager
CS Dealer Services
crank71
Member - Posts: 18
Posted: October 23, 2006 at 3:21 PM / IP Logged
Very cool, thanks Mike.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
