Vehicle Wiring Diagrams +/- Indicators
webpager
Member - Posts: 24
Posted: September 18, 2018 at 7:45 PM / IP Logged Link to Post Post Reply Quote webpager
I have a question about some vehicle wiring. I'm creating something for a 1999 Ford Taurus Wagon (programmed key, factory alarm). The wiring diagram is at: https://www.the12volt.com/installbay/alarmdetail/926.html
Some of the items show a positive or negative next to the wire color. For example, the factory alarm disarm shows as a pink/white jacketed wire, with a negative.
My question: I'm assuming that this is the ground side of the circuit, and that, whether latching or momentary, the disarm function needs to be grounded to disarm. Am I understanding that correctly?
I have some other questions that I will post under appropriate forum headings.
Thanks,
webpager
Webpager - Upfitter, computer guy, car guy. I can't tell the difference between Columbian or African coffee, but I knew at age 4 the difference between volts, watts and ohms.
geepherder
Platinum - Posts: 3,668
Posted: September 18, 2018 at 10:56 PM / IP Logged Link to Post Post Reply Quote geepherder
webpager
yes
webpager
Member - Posts: 24
Posted: September 19, 2018 at 5:47 PM / IP Logged Link to Post Post Reply Quote webpager
Thank you.
Funny about your ex, my chorus teacher said I had the perfect voice for writing.
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
