2001 Freightliner Truck, Still Runs When Key Shut Off
bat9905
Copper - Posts: 131
Posted: January 13, 2022 at 10:09 PM / IP Logged Link to Post Post Reply Quote bat9905
Hi have an issue and need a little help. I have an 01 freightliner with a simple 4 wire ignition switch. Constant 12 volt, acc, starter (push button) and ign have 12 volt proper key positions but vehicle still runs when key is shut off. Metering ignition while key is on 14 volts is present. Shut key off and it drops to 12. It should drop to 0 of course. I suspect ecm issue or something related because when I pull ecm fuse it shuts off. Any solutions would be greatly appreciated. Could a diode fix this temporarily?
bat9905
Platinum - Posts: 13,674
Posted: January 14, 2022 at 7:31 AM / IP Logged Link to Post Post Reply Quote i am an idiot
Any recently installed aftermarket equipment?
bat9905
Copper - Posts: 131
Posted: January 14, 2022 at 6:12 PM / IP Logged Link to Post Post Reply Quote bat9905
Just a pioneer head unit
bat9905
Posted: January 14, 2022 at 7:50 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Does the radio turn off when you turn the key off?
bat9905
Copper - Posts: 131
Posted: January 15, 2022 at 11:54 AM / IP Logged Link to Post Post Reply Quote bat9905
Yes it shuts off acc wire at the switch is off when key is off.
bat9905
bat9905
Copper - Posts: 131
Posted: January 19, 2022 at 9:26 PM / IP Logged Link to Post Post Reply Quote bat9905
Ignition relay ended up being bad and back feeding to switch
bat9905
Posted: January 19, 2022 at 9:45 PM / IP Logged Link to Post Post Reply Quote i am an idiot
Thanks for letting us know what it was. It may help somebody else with the same problem down the road.
Thursday, May 23, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
