2005 caravan rostra cc problem
weirichk
Posted: August 25, 2007 at 10:02 AM / IP Logged
I purchased and had installed a Rostra micro-cruise 4 for my 2005 Dodge Caravan (4 cylinder engine, automatic, power nothing).  While it took forever to find the tach signal we finally got everying hooked up and working - at least we thought we did.
When we engage the cruise, it holds speed for a second or two and then dis-engages.  Any ideas or suggestions as to where the problem may be would be appreciated.
Thank you,
Kurt
ranger svo
Copper - Posts: 70
Posted: August 26, 2007 at 4:44 PM / IP Logged
First I never use the tach connection. It always seams to cause problems. So I tyrically ground the blue wire.
Now I have never had a problem putting a cruise on a Caravan, but I also don't use the micro cruise 4. Can the MicroCruise 4 be set to 36,800 pulses per mile (thats with the 250-4369 pulse adapter)? Or do they make a pulse adapter that will allow the microcruise to read the Caravans VSS signal?
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
