07 chevy silverado classic cruise control
Jockey09
Posted: January 10, 2008 at 3:34 PM / IP Logged
anyone done a 07 cruise control in chevy silverado   classic body style and v6?   any parts i need thanks
cam/maa
Platinum - Posts: 12,488
Posted: January 10, 2008 at 4:50 PM / IP Logged
All you need is a switch for these vehicles because it uses a drive by wire that doesn't require the need for an actuator.
zziggy
Member - Posts: 20
Posted: February 25, 2008 at 12:58 PM / IP Logged
For your 4.3L V6 engined Silverado or Sierra Classic (OBS 2007)
You'll need the whole cruise control kit.
Handle, wiring, servo, throttle connection.
I'd suggest the SCS3342 and 5318 handle as the most economical way to add a quality cruise control.
Its less than $160 complete. You can also add the OEM handle if you don't want the Added arm handle.
You can step up to the all plug-in cruise for about $380. Its all plug-in accept the handle which still needs hardwired to the junction at the column because GM left out 10˘ worth of wire and plug on the non-cruise trucks.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
