armrest ideas
puttster
Member - Posts: 24
Posted: July 14, 2008 at 9:05 PM / IP Logged
I want to add an armrest, up near the top of the door where you rest your arm for the low rider look.  Right now there is just smooth door panel there, not molded plastic, because I have a 1965 Ford. Can anyone give me some ideas how to build and mount an elbow rest?
Platinum - Posts: 13,726
Posted: July 14, 2008 at 9:28 PM / IP Logged
We may need a little better explanation of the "Low rider look" to be able to help you.
puttster
Member - Posts: 24
Posted: July 17, 2008 at 5:34 PM / IP Logged
Well, maybe not really low rider, but something that you can comfortably lay your left elbow on when you're driving with the left hand.  I was thinking of mocking up a structure with paper mache, making a mold with fiberglass on that and then laying the mold back on the door and filling it with kitty hair or maybe expanding foam.  Then there is the problem of fitting a cushion on top of it in a nice looking way and also fastening it to the door.  Well, that's why I'm here , to get ideas on how to build such a thing.
Melted Fabric
Silver - Posts: 509
Posted: July 18, 2008 at 1:29 PM / IP Logged
Can you provide a picture of your door/interior as-is?
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
puttster
Member - Posts: 24
Posted: July 18, 2008 at 2:28 PM / IP Logged
broken-fish
Posted: August 22, 2008 at 5:48 PM / IP Logged
you could check suppliers of classic car interiors not necessarily only fords i know vw bugs have a pretty small armrest/handle to close the door if you dont like the look just use the top cushion or check salvage yards
Broken-Fish
boogeyman
Silver - Posts: 359
Posted: August 22, 2008 at 6:31 PM / IP Logged
  Use floral foam to make a mold, It can be purchased at wal-mart inexpensively.........It can be sanded to shape VERY EASILY........Once sanded to shape applyfiberglass resin....Then Matte .........sand....duraglass.....sand...........body filler.........sand...............cover with fabric of choice..................TRY IT ITS ACTUALLY FUN............good luck
