fiberglass hood
djchrishim
Posted: August 27, 2008 at 8:48 PM / IP Logged
I own a 1993 Ford Escort and the hood is plain. It is just a flat straight hood. The aftermarket hoods are the same thing just in carbon fiber. I want to mold a hood with some heat extractors, lines, and such. So how should I go about molding a hood?
thunda_hawg
Member - Posts: 46
Posted: August 28, 2008 at 1:20 PM / IP Logged
a couple questions
do you have any experience in fiberglass overlay and molding ?
what specific purpose for the changes(vents etc.)
89' 240sx
Rockford t8004
boston z6 comp.
eclipse 3432
polk MM 8"
Taylor owes Joe a Sandwich
djchrishim
Posted: August 28, 2008 at 10:41 PM / IP Logged
Nope, but I think I have the concept of fiberglassing and my brother has fiberglassing experience. I just want to give my car a tuner look considering its a mazda engine in it.
jayson33
Copper - Posts: 165
Posted: August 28, 2008 at 11:41 PM / IP Logged
Are you building on existing hood or do you mean building a complete hood from fiberglass hood from scratch ?
My wife thinks bagging a truck means you kick it in the truck nuts
djchrishim
Posted: August 29, 2008 at 10:56 PM / IP Logged
Probably an existing hood
jayson33
Copper - Posts: 165
Posted: August 31, 2008 at 12:52 AM / IP Logged
What Style of hood a ram air type ? Do you you want it to be a functional hood or for looks.
djchrishim
Posted: September 02, 2008 at 1:31 PM / IP Logged
i want to make the hood kinda like this fiberglass hood -- posted image.
jayson33
Copper - Posts: 165
Posted: September 02, 2008 at 2:03 PM / IP Logged
I would use playdough to get it to the shape and size you looking for then lay fiberglass & resin over it And no the resin will not stick to playdough it will pull right out. I have use this process alot I just used it to repair a
74 Corvette's front air dam It hit a cat  but I just molded playdough to follow the contoure of the air dam laid the f-glass over  pulled out putty put couple of layers over back side the owner could not tell where the repairs were even done.
jayson33
Copper - Posts: 165
Posted: September 03, 2008 at 10:35 AM / IP Logged
I will explane a little better model clay works best you can get it by the brick from most hobbie stores cheap
it can be shaped easly and smoothed easly with water once you have it shaped let it dry a little in the sun about an hour just to burn of excess water if used. Then spray with primer about 3 good coats will work this
layer will stick to the fiber glass when clay is removed to give back side a finished look not nesary but looks
nice. Its really easy to do you can make some really complex shapes with this process the clay can be molded very quickly and easly. Hope this helps take you time it will look great
djchrishim
Posted: September 04, 2008 at 8:34 PM / IP Logged
thanx. i'll try it
