denatured alcohol
hvaughn
Member - Posts: 34
Posted: September 07, 2005 at 9:52 PM / IP Logged
what is the difference b/w this and isopropyl alcohol?
I bought some isopropyl (70%) today from wal-mart, but after reading on here it seems that I may need to go back and get some denatured alcohol or acetone. I need this to clean the interior before putting in some raammat.
Please advice b/c I would hate to improperly clean and have the mat falling off in the future.
Please help....
SoundAudio
Copper - Posts: 242
Posted: September 07, 2005 at 10:49 PM / IP Logged
The isopropyl alcohol is deluted with water.  The denatured alcohol is staright 100% alcohol wihich is why it evaporates quickly if you leave the cap off.  They will both work basically the same, the denatured will clean it a little better but I have had success with both.  The denatured alcohol can be purchased in the gallon so that is nice.  I don't think using one over the other will cause your rammat to fall off.  If you are that concerned add some spray adhesive to the surface before applying the mat.  And as always make sure to press and rub it to the surface well.
Good Luck!
-Thad
kelrx8
Member - Posts: 10
Posted: September 11, 2005 at 2:32 AM / IP Logged
btw denaturated alchol is used for emission's also ;)
jlord16
Silver - Posts: 322
Posted: September 11, 2005 at 4:14 AM / IP Logged
I agree, use a bit of spray adhesive, it wont hurt to make sure
Clarion DB36MP
Infinity Kappa Perfect 10"
Respone 800w Mono
ALPINE MRP-F250
*Custom fabrications*
