fiberglass boxes for 1999 galant
sseddie
Posted: June 09, 2006 at 2:57 AM / IP Logged
Hello im new to this website i was looking for a good place to show me how to make fiberglass boxes for my 1999 mitsubishi galant gtz and i guest i found it ive been looking at many post about diff speaker boxes and i like wat ive seen i go to alot of car shows and im into alot of hard hitting bass myself i got 2 15 inch kicker CVRs running 1000 rms at 1 ohm and im looking on making a box for my subs for show and spl which is wat i do alot also theres alot more stuff i wanna FG and im hoping ppl on this great site can help me out this being my first time working with it and also im wanting to make my full trunk out of FG so i can display my subs and amp at the same time for shows. thanks Eddie.
mi_what
Copper - Posts: 208
Posted: June 12, 2006 at 1:49 PM / IP Logged
Street Styles huh? Tell your boy with the blue xterra on duece dueces mi_what said hi. If you want to make your entire trunk out of FG you will have to build the boxes, amp rack, etc in the trunk and just stretch fleece over the boxes and under the weather stripping until you get the shape you want then lay down some resin and chopped mat until the fleece portion is solid enough to be removed from the car without warping (probably about two to three layers) then just add fiberglass reinforced body filler and start smoothing it using body filler. then you just lay it back down in position and re-apply the weather stripping. That's it. probably be your best bet considering that two FG boxes for 15s would probably the entire trunk space anyway.
Melted Fabric
Silver - Posts: 509
Posted: June 13, 2006 at 11:26 AM / IP Logged
If you are not in a rush, I would in addition to what mi_what said, I would buy the www.caraudiohelp.com DVD pack on Fiberglassing.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
