I want to update my old box
judgedread
Member - Posts: 18
Posted: August 23, 2006 at 12:56 AM / IP Logged
How do i go about making my old box look nice and shiny like fiberglassed boxes without using fiberglass.I want to update my old box -- posted image. Would a simple primer, paint and clear coat work.
Platinum - Posts: 12,488
Posted: August 23, 2006 at 8:39 AM / IP Logged
Is the box carpeted now ? If so you would need to remove the carpet. Sand down the box to MDF and then you can use a polyester primer to build up the MDF. Take into consideration that the MDF will soak up alot of primer but you will be able to sand down the primer and then paint.
judgedread
Member - Posts: 18
Posted: August 23, 2006 at 1:05 PM / IP Logged
yeah it has carpet, so whats a polyester primer.
