Fiberglassing dash and interior panels
austincustoms
Copper - Posts: 232
Posted: August 31, 2006 at 3:11 PM / IP Logged
I'll be starting a project for a '73 Mustang hatch in the next week or so.  First off, they want the entire dash fiberglassed and painted, but besides adding tweeter pods, they want it to look stock.  Because the dash has some holes in it, I'm just going to lay a few layers of FG over the entire thing.  My first question is, part of it is heavily padded, and covered in vynil.  If I remove it, i will lose the whole look.  Can I fiberglass over this without it warping too much?
I'm also remaking the side panel in the hatch area to add a sub box.  I'm going to cut a piece of MDF to get the footprint I want, build a box behind it, and stretch the fleece up to the weatherstripping.  The problem is, the panel I'm remaking is a single piece that goes from the back seat (it's a 2 door) to the hatch.  what is the best way to cut this panel in half and attach the origional front to the new back?
auex
Platinum - Posts: 5,041
Posted: August 31, 2006 at 11:43 PM / IP Logged
You need to remove the vinyl, glass won't stick to it.
You will need to cut it and try to blend it into the new panel. You could possibly incorprate it into your panel permanently. A trip piece may help cover any gap you have.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
